ranch king tractor
/ ranch king tractor #1
allen6634
hawesville
600 ford
today i got the tractor split there must have been 5 gallons of water in the bellhousing i know why the clutch wouldn't release , it is a mess in there , even the pto clutch was stuck, now i just need to put it back togther, and find a way to stop the water from getting in.:)
/ ranch king tractor #2
I am not familiar with Ranch King Tractors but often rain water ends up getting in through cracked shift boots. All I saw on King Ranch via Google were garden tractors. If this is what you have, is the engine air cooled or water cooled?
/ ranch king tractor #3
I think they are chinese tractors sold through "Ranch King" stores. A rebranded Foton.
OP, is there a plugged drain hole in the bottom of the bellhousing.
from what i have learned this tractor is a foton tractor, it was sold at a rual king store,im not sure but i would think that there must be some sort of plate that might not of been installed during the assembly , because there is a big hole in the bell housing , the step and part of the dash is bolted on when every thing is on the hole is not noticable , but yet it is a point of entry for water, i know that i am going to make a plate and sealicon it be for i call this done.thank you for your reply. and no there is not a hole in the bell, i am thinking about drilling a 3/8 hole in there, just in case.
/ ranch king tractor #5
Sounds like you are getting your arms around it. Good luck.
thanks the only problem i see is where do i put all the oils that ran out on my floor back in this thing .
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 HINO 195 18FT...
More info coming soon. (A64557)
More info coming...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2009 International 4300V 24ft. Cab and Chassis Truck (A64194)
2009 International...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
