ranch king tractor
/ ranch king tractor #1
allen6634
hawesville
600 ford
today i got the tractor split there must have been 5 gallons of water in the bellhousing i know why the clutch wouldn't release , it is a mess in there , even the pto clutch was stuck, now i just need to put it back togther, and find a way to stop the water from getting in.:)
/ ranch king tractor #2
I am not familiar with Ranch King Tractors but often rain water ends up getting in through cracked shift boots. All I saw on King Ranch via Google were garden tractors. If this is what you have, is the engine air cooled or water cooled?
/ ranch king tractor #3
I think they are chinese tractors sold through "Ranch King" stores. A rebranded Foton.
OP, is there a plugged drain hole in the bottom of the bellhousing.
from what i have learned this tractor is a foton tractor, it was sold at a rual king store,im not sure but i would think that there must be some sort of plate that might not of been installed during the assembly , because there is a big hole in the bell housing , the step and part of the dash is bolted on when every thing is on the hole is not noticable , but yet it is a point of entry for water, i know that i am going to make a plate and sealicon it be for i call this done.thank you for your reply. and no there is not a hole in the bell, i am thinking about drilling a 3/8 hole in there, just in case.
/ ranch king tractor #5
Sounds like you are getting your arms around it. Good luck.
thanks the only problem i see is where do i put all the oils that ran out on my floor back in this thing .
2020 INTERNATIONAL MV607 4X2 S/A 26FT NON CDL BOX TRUCK (A67148)
2020 INTERNATIONAL...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
2153 (A65055)
2153 (A65055)
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2001 Pierce Pumper Fire Truck (A64556)
2001 Pierce Pumper...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
