1952 8N carb issue
   / 1952 8N carb issue #22
Glad you got her running again. Those carbs are about the simplest carbs in the world to work on and adjust.
   / 1952 8N carb issue #23
yep.. all but the worst rusted and pitted are rebuildable
   / 1952 8N carb issue #24
I'd try using some Sea Foam. It has straightened out carburetor problems on my old Gravely when I had it and a couple older lawn mower engines and generator engine.
Ralph
   / 1952 8N carb issue #25
i look at sea foam like this.
While it may not help.. it SURE will not hurt. and if it even only helps a lil.. I'll take it.
I've used it in small engines with good results too. never any horror stories.. etc..
I use marvel mystery in the 8N and other gas engines. I had a 350 in a truck that had a lifter that had trouble priming. I changed the oil, added a quart of mmo to the crankcase and lifter quited down. Unfortunately sold the truck before I could change the oil again to see if it was a permanent fix. Never used seafoam, what exactly does it do??
   / 1952 8N carb issue #27
those spin on adapters look nice.. care to share the part # and where you got them?
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
