Mechanical pop up dovetail
/ Mechanical pop up dovetail #1
minner
Arab, AL
Kubota M7040 cab
Guys, my memory is failing me help me out here.
I have been shopping trailers for weeks. I have decided to go with a 20+5 GN with a "pop-up" dovetail, and standing ramps. Ok, back a lot of years ago, way before hydraulic doves became popular; my dad had a trailer that had a popup 5' dovetail that was mechanically operated via trailer jack. It was a production trailer, not modified. The beauty of this system was that you could pop the dovetail up while loaded. It did suck popping it up loaded but it worked EVERY time and no high costs of a hydraulic system. It made more use out of the extra 5' on longer loads. Does anyone know of the maker of a trailer like this? If not I may just order a manual pop-up and modify it later.
/ Mechanical pop up dovetail #2
I saw one for sale the other day... it was either a pj or cornpro- probably pj. It was like an '02 in pretty decent shape but needed tires soon for $3200 iirc.
Thanks, I have read that thread in my research, lots of great opinions.
/ Mechanical pop up dovetail #5
Bri-Mar makes a trailer like you are talking about. 20+5 with a jack for the dovetail. It's pretty neat as the whole dovetail not just the deck will jack level.
/ Mechanical pop up dovetail #6
Something like this???
Yes its a custom made unit but works great. Been thinking of upgrading to a bigger hydraulic dovetail trailer only problem is the price of them. The popup dove is very useful for hay, lumber,steel or equipment.
No not exactly. But since you posted could you share the specs on your pump and cylinder(s) setup? I think I could easily adapt a pump into the setup I am looking at.
/ Mechanical pop up dovetail #8
I just unpin the back and lift it up. Then to pieces of 2x2 tube fall down and are pinned in place to hold it up. Real simple design. To lower it I just push the tubes forward and it falls down. It is heavy so most of the time I use a loader to lift it but I can to it by myself if I have to. This trailer has detached ramps and no leggs to support the rear so I use wood blocks while loading which has worked good for last 15 years.
I'll try to get photo this weekend of it.
Yes, thanks, but like I said in the original post the idea is to be able to pop it up while loaded.
/ Mechanical pop up dovetail #10
All you would need are 2 hydraulic cylinders an a pump to push it up. Fairly easy to fab up if you were around here I would say stop by shouldn't take more than a few hours to weld up.
/ Mechanical pop up dovetail #11
I would think a couple Harbor Freight cherry picker (engine hoist) rams with built in pumps would work or a couple 1.5" rams with something like a porta power head unit to provide the hydro pressure.
Chris
Y'all have me thinking now. One could adapt a "Porto-power" style set to make a manual setup, if there is enough reservoir capacity available.
Did some research on 12v systems:
12v pumps run about $350 and cylinders between $100-200. Most of the manufactured with hydraulic dovetails sell the components but are a little more expensive than a generic COTS pump.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Brake Drums (A62613)
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
Caterpillar 345B/BL Excavator Vol. 1 and 2 Service Manuals (A63117)
Caterpillar...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2010 BOBCAT E80 EXCAVATOR (A64279)
2010 BOBCAT E80...
