Mowing Bush hog quit cutting
/ Bush hog quit cutting #1
1nerveleft
Virginia
Ford 9n2n hybrid
I have a ford 9n2n hybrid. I use an old 5 ft bush hog, type unknown. The hog quit cutting suddenly, has a louder than normal sound. The shearing pins are fine, the blade rotate but don't cut or tear. They gently cross the weeds. I think my rpms on my pto may be slower, not sure. What else can cause to stop cutting?
/ Bush hog quit cutting #2
Do you only have shear bolts or is there a slip clutch as well?
One of my cutters has a key on the underside where the blade carrier bolts on to the output shaft. I sheared that key once and couldn't figure out why everything was turning except for the blades.
/ Bush hog quit cutting #3
Missing teeth? Take the lid (or fill plug/breather) off the gearbox and see if everthing's hunkydory in there.
A broke/missing shear or key pin would sure be a nice alternative, though.
2018 CATERPILLAR 930M WHEEL LOADER (A65056)
2018 CATERPILLAR...
2018 DODGE RAM 2500 (A67714)
2018 DODGE RAM...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
CASE CX60C EXCAVATOR (A65056)
CASE CX60C...
LOOK! (A63111)
LOOK! (A63111)
2018 Ford Explorer AWD SUV (A66738)
2018 Ford Explorer...
