What metal drill bit for putting a Piranha on?
/ What metal drill bit for putting a Piranha on? #61
Roy the .9 hash mark on the carriage is not visible. It will be almost another 1/10 of and inch of jaw opening before it will be visible. The carriage is slightly past the .8 hash mark. The numbers are to the left of the hash mark they represent. You need to get out your own calipers and have a look at them. When fully closed the carriage will be at the 0 hash mark, and the owner should adjust the dial to read 0 also. Which he has not done. We can only estimate the dimension as show at around .805 as this caliper is out of adjustment as evidenced by the hash marks on the carriage and the dial are not in agreement. I too wish the owner of this caliper would show us this caliper fully closed.
James K0UA
You (and others) are assuming the first hashmark is the "zero"...based upon my experience, I'm assuming the first hashmark is for .100.
Well, reckon we do need the OP to post a picture of that caliper closed.
As I wrote previously, we expect the OP to be able to use his own calipers...
/ What metal drill bit for putting a Piranha on? #62
Wonder if he drilled them holes yet?:zzz:
/ What metal drill bit for putting a Piranha on? #65
On my pair if I can see the number 8 on the body it is 8???. You do not go back one #.
/ What metal drill bit for putting a Piranha on? #66
OK... here is my properly zeroed caliper set to various dimensions
/ What metal drill bit for putting a Piranha on? #67
I guess the last thing to be seen is how the Princess handles being PROVEN wrong. By a bunch of non-QC professionals, at that.
Oh...and how the OP's bucket project comes out. That too.
/ What metal drill bit for putting a Piranha on? #68
I did request (via a PM) the OP to post a picture of his calipers closed...then we'll have the answer.
/ What metal drill bit for putting a Piranha on? #69
/ What metal drill bit for putting a Piranha on? #70
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
Cybex Ab Crunch Workout Machine (A59317)
Cybex Ab Crunch...
2017 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2017 KENWORTH T680...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
