Remote control for gate release / auto closer
/ Remote control for gate release / auto closer #1
Shimon
Sedro Woolley, WA
Kubota L3400 (gear driven)
Our sheep are getting more and more wily each year and it's hard to get them penned up in their shed so we can administer vaccines, trim their hoofs, shear them, etc.... I put in a new, light weight gate and I want to be able to close it with a remote control "key-fob" from a distance. The gate will have three or four bungee cords attached so that when the gate is open, it will naturally want to close shut. I will then have a latch mechanism that holds the gate open. When I press the remote control, a 12VDC solenoid will pull the latch allowing the gate to shut. If the gate doesn't close quickly enough, I can tighten the bungees, add more bungees or even install one of those gate spring closer things. Power will be supplied from a 12VDC power brick (from an old laptop) that will plug into an outlet in the shed. The components will be mounted in a sealed plastic J-box with the receiver antenna and solenoid mechanism sticking out.
This is the solenoid I plan on using: Guardian Electric - LT6X12-I-12D - Solenoids - Solenoids (Mechanical Actuators) - Allied Electronics
This is the remote I was planning on using: Remote Control On/Off Switch - LEDs, 12 volt accessories
Here is a diagram of the latch and parts:
Here are some photos of the gate:
So, any suggestions? Not sure if the solenoid will be strong enough, but I can always find a stronger one from Allied or I can use an old stop-solenoid from a diesel Ford Lehman engine...those have quite a pull but also draw about 20 amps. I would like to keep the solenoid under 4 amps so I can use a 12V power brick I have laying around. Also, any suggestions regarding the remote would be appreciated too. Or any suggestions/comments about the design in general. Thanks!
/ Remote control for gate release / auto closer #3
I know exactly what you need, the electric truck latch out of a wrecked car. No matter how much "spring" you put on the gate it won't bind and they draw less current than a solenoid would.
You meant "trunk" latch right? I like this and will investigate. There are a number of wrecking yards around here...I'm sure I can find something.
Thanks for the replies.
/ Remote control for gate release / auto closer #5
If it came down to a draw problem shimon as in too much for the PS your wanting to use, you could always do a small 12v battery with a battery tender to keep it alive. Then the rest of your plans would remain the same. It wouldn't even have to be as big as a lawn tractor battery really and it could take pretty good short draws.
/ Remote control for gate release / auto closer #6
How about a drop gate on the remote.
And a normal swing gate for the other 99.9% of the time you go in and out......
Good luck
/ Remote control for gate release / auto closer #7
Yes, trunk latch. Dam cell phone up date auto correct is going crazy but it is the easy way to take and up load photos.
Like this.
Like this.
Thanks for the photo. I agree about the "smart phone" comment. Sometimes they ain't so smart.
On another note... I tried the bungees to see if they would close the gate... they would not. They can't pull the gate "over center"... Once I pushed the gate past the over center point, it would close.
So I am going to get a spring: http://www.gateshut.net/buy-your-gate-closer-here.html
/ Remote control for gate release / auto closer #9
I built a bump gate at our farm for 4 wheelers where I uses a broken garage door spring to bring it back to center.
It was the style spring that fits over a 1" or so shaft and is would around to provide tension to the cables, normally. Once it broke it made it down to the junk pile and was reused so an open gate bent it side to side and it's action would return the gate to center at rest.
/ Remote control for gate release / auto closer #10
So I am going to get a spring: Gate Closer, Farm Gate Latches, Automatic Gate Closers
If you are only opening your gate 90 degrees, you can make a set of hinges that will make the gate rise on the outside, & lean in, when opening to either direction. Then the weight of the gate will make it close without a spring. Not sure how fast you want it to close.
To do so, make your hinge pins adjustable and stagger them from plumb when the gate is closed, but plumb & level the gate when closed. The more you stagger the top hinge pin from the bottom, The more the gate raises & leans when open & the faster it closes when turned loose.
/ Remote control for gate release / auto closer #11
You could always turn off auto-update and manually check each week. If you have a number of apps on your phone and they are all set to auto-update you'll be downloading updates almost constantly. Be nice if you could specify when updates are performed, like between 1 and 3 AM when you are not likely to be using the phone for anything else.
/ Remote control for gate release / auto closer #12
spring hinge on the gate, available at lowes.
/ Remote control for gate release / auto closer #14
If it has to swing both ways there used to be pretty common self centering gate hinges that looked pretty much like the ones you have, except the strap part had an upside down V notch in them so when the gate opened either way, it rode up on the V, then gravity returned it to center to close. Of course both hinges have to be positioned with the L up, like your lower hinge. Maybe they don't make them any more because I couldn't to find a photo of them. They'd be easy to make from your hinges but would wear out faster than the old heavy duty ones I remember.
As far as the the trunk/door latch, it would be great if it is remote control, all you have to do is get the car key with it.
Here's a photo of a similar one but the whole hinge is cut at an angle instead of just a V notch.
/ Remote control for gate release / auto closer #16
Shop Stanley-National Hardware Self-Closing Gate Kit at Lowes.com
lowes $19.96
i now do access control for sheeple, you could issue each sheep a id card, train the sheep to walk in front of the gate, add a long range prox reader to the pole as they pass in front of the gate their badge would be read. upon reading the badge the 48 volt mag lock would open allowing the sheep to enter. only problem is you would have to have an emergency egress plan for the fire department or in your case pita.
2004 AMMANN AV33E Smooth Drum Roller (A61166)
2004 AMMANN AV33E...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63118)
2022 Schulte...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2026 Steel Pines Cargo 8.5x20 Enclosed Trailer, VIN#7FWBE2021T1037982 (A61166)
2026 Steel Pines...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
