Mowing DK45SE dropping rpms going uphill
/ DK45SE dropping rpms going uphill #1
wv joe
Member
Gay, WV
Kioti DK45 SE HST
Posted this problem under the repair heading, but not getting many responses. Anyone run into a problem where the tractor runs fine on level ground but rapidly drops RPMs going up hill (eve a slight grade)? Problem happens when mowing or with PTO off, at times runs ok for a while before issue occurs, other times happens right away. Did all the obvious, added a "water remover" to fuel just in case, replaced fuel filter and bled, still NG. No sign of leaks, oil & coolant ok. Does blow white smoke after problem occurs, which seems to indicate a fuel issue, but at a loss right now.
/ DK45SE dropping rpms going uphill #2
what range and RPM are you at?
I'm not an expert, by any means, but I've already noticed with mine that if I am driving up a slope in MID, and the RPMs are not high enough, it will bog. If the RPMs have to be higher than I am comfortable with to keep it from bogging, then switching into LOW and going a little slower gets me there. I haven't tried it, but I doubt HIGH would give very good results going uphill at any RPM.
$0.02
/ DK45SE dropping rpms going uphill #3
Yes, H is not for climbing hills. What RPM range are you at when trying to do the hill thing?
Sounds like it could be the lift-pump.
What # of hours are on the machine?
2500 RPM usually mow in M unless going up a steep hill, then L. This is happening even with the PTO disengaged, in L, on a hill I normally could climb in M with the PTO engaged. RPM drop off is sudden and severe, not the gradual loss of RPM going up a hill in too high a gear range.
$0.02
I agree, only use H when I'm traveling on the pavement to get to my back field. Other than that, M is the usual, with L as needed on the steep hills. Mowed the last 2 years with it and never had this issue. Less than 200 hours on tractor, unfortunately turned 4 in March (end of warranty).
/ DK45SE dropping rpms going uphill #6
Have you changed your air filter? If it's clogged it will show up more under a load like mowing uphill...And there is serious debate among those in the know about whether shaking or blowing out a filter with compressed air, on high compression diesel engines is advisable. I'm leaning toward the most current thinking: not to try to clean it....
Fuel starvation will result in loss of power under load, if the lift pump is failing or marginal. I don't know if it can be removed, disassembled and put back together after cleaning.
Less than 100 hours on air filter, looked ok. Kind of ruled out an air problem since that did happen on my Mechron, but smoke then was black, smoke on the tractor is white, which appears to indicate a fuel (lack of) problem. Thanks!
/ DK45SE dropping rpms going uphill #8
Do a quick idiot check of the parking break and the rear remote. Also look at your implement to be sure it is lubed and working properly.
/ DK45SE dropping rpms going uphill #9
Sounds like a lift pump issue. Does it happen if first running tractor of after it has been running for done time. If it accrues after tractor has been running for a time if could indicate a tank vent problem as well. Next time it happens loosen fuel cap to see if it makes a difference. If it doesn't I would check the lift pump or kinked fuel line. Check the easy free stuff first.
/ DK45SE dropping rpms going uphill #10
This might sound odd, but try lifting your foot OFF the pedal some as you notice the RPMs drop.
It varies, first couple of times it did ok for a while, then got worse. Last time happened pretty quickly (although it was running while my neighbor tinkered with it). Couple of guys at work also thought it was a venting issue, so I will try it with a loose fuel cap to see how it goes.
Not much choice, will stall if I don't. Have to repeatedly push and let off to get up the slope.
/ DK45SE dropping rpms going uphill #14
Hmm...I read where at least one fuel filter was changed. Does this model have one filter or two? Typically diesel engines have at least two filters, the first being a fuel/water separator that filters down to 30-40 microns or so, followed by a secondary filter that screens down to 10 microns or less. Just wondering if there's another filter that's clogged.
Along these lines here's similar thread worth reviewing: http://www.tractorbynet.com/forums/kioti-owning-operating/181159-loss-power.html
Personally I've seen some really nasty crud in diesel tanks and filters. To completely rule out the fuel issue I'd drain and flush the tank, refill with fresh fuel, and try it again with new filters.
/ DK45SE dropping rpms going uphill #15
Does your fuel come from a petcock exiting the bottom of the tank. Could be a piece of debris blocking it as you start the climb?
larry
7in. Auger Bit (A65640)
7in. Auger Bit...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
FLAT BED (A65643)
FLAT BED (A65643)
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
White 5100 12R Planter (A66285)
White 5100 12R...
