Shopping for a Zero Turn Mower
/ Shopping for a Zero Turn Mower #1
SOS
Fredericksburg, VA
NH 45 A (2006)
I have about 13 acres of which 5 require mowing with some obstaclesand fairly flat. I致e been using a JDLA175 for the past 5 years and it has been breaking every month this summer Iam wearing it out. I need somethingstronger but the boss says I have a spending limit of $5,000 (which I can stretchwith some sweat talk).
Here is what I have found around here in my price range:
Kubota ZG127 E or S 27 HP (54 in) -- $5,300
John Deere Z655 27 HP (54in) $6,100
Swisher -- ZTR2460KA 24 HP (60in) $4,900
eXMark -- QTS691KA502 23 hp (50 in) $5,800
I would appreciate feedback on these and other suggestions.Thanks.
/ Shopping for a Zero Turn Mower #2
In my area the Hustler Brand is very popular. The largest lawn maintenance company in our County uses these zero turn mowers for almost all their accounts. Three of our immediate neighbors own them, and they all tell me of the quality of these mowers. I plan on buying one in the Winter when the prices drop somewhat. Best wishes.
/ Shopping for a Zero Turn Mower #3
BadBoy mowers are very maintenance friendly and good quality, they can be found at about 1/4th of the Tractor Supply stores I've been to as well as online. Dixon is the company that actually coined the term "zero turn mower" and has been in the business nearly longer than anyone, they have dealers various places. Cub Cadet has been in the "zero turn" market longer than just about anyone (before they were called zero turn mowers) and they can be found all sorts of places. All three are worth a look before committing to anything.
While I can't give model specific opinions on your choices, my overall thoughts on the brands mentioned above:
Anything as small as a zero turn by Kubota or John Deere isn't manufactured by them. The high end models they have the parts made by third parties (lowest bidder) and run it down their own assembly lines to have the benefit of hands-on Quality Assurance. Their lower end models are all manufactured and assembled by the lowest bidder, painted to look like a John Deere or Kubota and have a huge price markup placed on it to cover warranty services after the sale. I'd find the equivalent model by a "lesser" name and save a buck or two unless there were some key quality differences on certain components. I have 42" Craftsman and John Deere tractors that are the same age, same frame, same motor, same deck. The only differences on the machines are the design of the spindle where it attaches to the blade (simply to make blades non-interchangeable), the locations of the gas tank and battery are swapped, the JD has a garden hose connector for a deck cleanout, the Craftsman has a hydrostat and the JD a gear drive. The JD gear drive was $200 more than I got the Craftsman hydrostat for, and an identical JD hydrostat would have been $400 more. Needless to say I kick myself for buying the JD considering it travels the same ground as the Craftsman and is broken down twice as often. If you need a $50k+ piece of hardware, JD and Kubota are worth a look; but on the small stuff they don't manufacture, the better long term investments are found elsewhere in my opinion. While it's just 'luck of the draw' that my particular JD breaks down more than my Craftsman; my point is buying it just cause it says JD on it (or Kubota for that matter) doesn't mean it will provide trouble free service, it just means it costs more overall. The main reason I can see to go with JD or Kubota would be if you have really excellent dealers in your area. An excellent JD or Kubota dealer that makes the purchase worth the price after the sale is the only REAL reason to pay their prices for their hardware. The quality of service from a high quality JD or Kubota dealer really can't be matched by dealers of any of the other manufacturers. On that note, if you have a high quality locally owned mower repair shop in your area, they can fix any of the zero turn units as well as any dealer can and do so at way less cost simply due to less overhead costs (owning a franchise dealership costs gobs).
Swisher is a good company that manufactures most of their steel work and purchases high quality components and hardware for final assembly. What they purchase from third parties is likely from the lowest bidder same as John Deere and Kubota, but the standards of quality seem to be higher (likely due to their focus being on their large equipment). John Deere and Kubotas generally have "prettier" appearance than Swisher on the machines I've seen, but the Swishers seem to be more stout of a machine (heavier gauge steels, better powdercoated finishes, thicker welds).
eXMark is now owned by Toro. Before settling on this model I'd check out the equivalent Toro and see which has the higher quality components. Beyond that I don't have any experience with them (or Toro) to advise or comment any further.
Hustler is another oldie that was early in the production of zero turn mowers and they've been in the mower game as long as Cubby or Dixon. They've always catered more to the commercial segment and I've not had any experiences with them but I'd say they're surely worth a look.
Myself, I'd go to a company whose lifeblood is mowers of the size and type you need who also manufactures their own designs. I think all these brands mentioned are selling good quality hardware overall, it's mostly what is going to be the best overall value for you and your needs. One of the best pieces of advise I can think of, test drive them all. As with most equipment you never know what you'll think of it until you have it in operation. SEAT TIME! :D
/ Shopping for a Zero Turn Mower #4
Look at Gravely Pro Turn series or a ZT-HD units.
/ Shopping for a Zero Turn Mower #5
Might want to re-check that info on the Kubota machines. Cub, Deere, Troybuilt, Toro, etc have their low end stuff made by MTD (or its "made by Deere", but its a clone of a MTD), but AFAIK, that is not done with Kubotas.
Yes, the hydro transmission will be made by someone else, its a hydro-gear ZT-3100 in the low end mowers (ZG100 series) and that's as better than most (most use a ZT-2800 for the mid level homeowner stuff)
Aaron Z
you've all been great. Now is there any difference between the Koler and Briggs & Straton engine worth noting?
/ Shopping for a Zero Turn Mower #7
I'll agree with user sox3 that the Gravely Pro-Turn 52 with the Kawasaki FS series(Heavy Duty) and ZT-3200 Hydro-Gear tranny would be worth considering(at $6199 MSRP) but for 5 acres you may want to sweet talk a little more and look at the Pro-Turn XDZ100 52"(which I have and HIGHLY recommend) with the FX691V Kawa(Commercial series) and ZT-3400 trannies(but will run $7499 MSRP).
/ Shopping for a Zero Turn Mower #8
Kubota ZG and ZD machines are designed and built by Kubota. I don't know about the new Kommander series
/ Shopping for a Zero Turn Mower #9
P.S.
I think if you do some research you will find that currently Kawasaki is considered the most reliable small engine on the market that is used universally across different mower brands. Their "engine series" ratings are FR(Residential), FS(Heavy Duty) and FX(Commercial). Personally, I would rate Kohler as #2(except the twin cylinder Courage series) with Briggs hot on Kohler's heels at #3(the Intek design was a bad move by B & S and the older Vangaurd series IMHO is better than Kohler). The Kohler/Briggs is pretty debated as both have some good/bad series.
/ Shopping for a Zero Turn Mower #10
I have a Dixie Chopper Silver Eagle and it has worked well the 11 years I have used it. Other than rear tires, belts, battery and filters no maintenance has been needed (except when I put some green (???) gas in it). Not sure its available in your area. Its built like a tank.
/ Shopping for a Zero Turn Mower #11
Any one have any info on a Ferris ZTR. I am looking to upgrade my Craftsman to something that rides a lot smoother. The Ferris has a spring and shock system for each wheel. It looks good but I have no experience with it. They come with both Kawasaki and Briggs engines.
Thanks again for the advice. I ended up with a zg127s Kubota. Cut my mowing time in half.
/ Shopping for a Zero Turn Mower #13
I think Ferris makes a really nice mower. I used a 1500 series to cut a couple of acres for a year. That being said, I think the suspension is overrated. Is it an improvement over a typical ZTR? I would say so. However, I also used a Gravely 260 with a suspension seat and pivoting front axle to mow the same area and felt it was a better ride. There are a lot of variables that make up the ride quality. Tire size, seat, etc. They all ride pretty rough if you're going fast enough!
/ Shopping for a Zero Turn Mower #14
Aaron Z
I don't think Toro has anything built by MTD. Might recheck your facts.
On edit, as far as ZTR's go.
/ Shopping for a Zero Turn Mower #15
From Wikipedia:
MTD Products - Wikipedia, the free encyclopedia
MTD builds or has built various other brands and store-brand lawn and garden tractors over the years, including:
Private Label Brands Produced
<extraneous info removed>
Toro (including some lower-priced models sold at Home Depot and Ace Hardware, perhaps others, although not all Toro tractors are made by MTD)
Aaron Z
/ Shopping for a Zero Turn Mower #16
From Wikipedia:
Aaron Z
Your quote from Wikipedia specifically states "garden tractors".....this thread discussion is regarding Zero Turn mowers(none of the Toro ZTR's are MTD's!!!!!).
/ Shopping for a Zero Turn Mower #17
I dont disagree with that (need to verify it though) but I was replying to sld who said "I don't think Toro has anything built by MTD" (which he later edited to specify ZTRs).
Next time I see some low end Toro ZTRs, I will have to look and see who makes them.
Aaron Z
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
1998 MAC 39' Frameless Dump Trailer (A66285)
1998 MAC 39'...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
