Oil & Fuel UDT vs. other brands
/ UDT vs. other brands #1
phastmac
Hackett, Arkansas
Kubota M7060,Kubota MX 4700hst, Kubota B7100hst, Kubota RTV 900,
Does anyone know of a good fluid to use instead of kubota's UDT. Would like to save money if possible.
/ UDT vs. other brands #2
I'm as cheap or cheaper than the next man but I won't use any hydraulic fluid other than Kubota to save a dollar and sixty seven cents or whatever.:) I use SUDT in HSTs but I might if I was using UDT in a geared tractor.
/ UDT vs. other brands #3
I agree with you john, just not worth it imo.
But it was a dollar & 69 cents i think:)
/ UDT vs. other brands #4
The dealers around here don't even use UDT. Its just universal tractor fluid, get a name brand oil if that makes you feel better. Shell, Gulf, Travelers, Mystic, take your pick. The important thing is you change it occasionally.
Some get a warm and fuzzy feeling from using Kubota fluids and filters. It won't harm anything to use Shell or whatever oil and a WIX filter either.
/ UDT vs. other brands #5
If you have a GST or HST SUDT does make a difference and many HST charge pump filters do not have a real good cross.
David Kb7uns
/ UDT vs. other brands #6
I did a change using Tractor Supply hydro, which met the stated criteria of UDT. It worked fine, no foaming or other problems, but there *was* a more noticeable whine under working pressure.
I switched back to SUDT for my next change, and it's much quieter. I'm sensing a lack of power as it gets hot working though. I have enough for another change of SUDT, and may do that to more fully purge the residual TSC fluid.
I understand the valves and hose diameters are smaller on the BX series, so it may be more noticeable for my BX24 than your tractor. There are dozens and dozens of threads on this very topic, but I find it hard to get a clean search for specific issues, questions, or topics. Try a variety of single key words, and perhaps you will find some of the longer or better discussions on this.
Paul
Thanks for the replies.
John Deere 6110M (A60462)
John Deere 6110M...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
20 Yard Dumper (A61166)
20 Yard Dumper...
JOB BOX (A62130)
JOB BOX (A62130)
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
