Grading York Rake and the BX
/ York Rake and the BX #1
Tollster
Benton, Pennsylvania
Kubota, BX23
I found a 6' stone rake and was curious if ya'll think it may be too big for my BX23? Owner said it was a cat 1.
It appears to be an older one with replaceable tines, it also has a grading edge that will flip down and a sod breaker in front of the rake with forward angled tines, perhaps its 3-4' wide( I think I can adjust the height of that as well_, along with adjustable dolly wheels (old style hand cranks). It appears to be a substantial unit. This will be my first implement with the BX as I have spent the last 300 hours using the loader and backhoe. I have the quick attachment but never used it.
Any pointers on its use would be great appreciated. Oh.. its 600.00 and I thought that was fair, he was asking 750. Wish I knew who made it as I would like to show it to ya'll before I buy and get your opinions.
/ York Rake and the BX #2
I have a Woods LR72. I use it some on the BX. It works good for raking the driveway or other light raking. You won't be able to pull a full load of dirt with a 6' rake but it will work decent.
Be sure the tines bolt on with 2 bolts or have some way to keep them in alignment. I am not sure what you mean by a sod breaker. Do you know the brand and model? Are you sure it will work with your QH?
You can get a new rake from EA for $514 minus the gauge wheels.
Landscape Rake for Compact Tractors
/ York Rake and the BX #3
I have used a weighted 6' rake [no wheels] on my 6100 for gravel, dirt and snow -with success. The blade edge, scarifiers and wheels on the rake you mention are handy features to have.
/ York Rake and the BX #4
Landscape Rakes are used ANGLED more than perpendicular to the tractor.
I adjust gauge wheels on my rake frequently, which requires using a 3/4" wrench on two collars on each gauge wheel assembly. Cranks would be nice, in principle.
Landscape Rake is a ground-engaging implement which requires some power to operate. You a marginal with 23-hp seeking to pull a 6' heavy rake. Rakes, like disc harrows, work best pulled 4-5 mph.
You are in Pennsylvania and I believe York (brand) Rakes were originally manufactured in York, Pennsylvania.
I am NEUTRAL on purchase.
LINK TO YORK BRAND RAKE WEB SITE:
http://www.yorkmodern.com/catalog/york-rakes-c-21.html
York Rakes : York Modern
I checked again today, its a York rake Model RS, with scarifire and dozer blade like this one, only older with some surface rust, the height adjustable rear wheel have hand cranks, all bushing have zerks, I did not see any age cracking on the wheels, he claimed to have used it with a Kubota 8500. Still rather undecided if the BX will be able to pull it, although it seems like a fair deal, I think it would be over 1500 if purchased new although it appears to be more than 20 years old and there are some design changes from the new model.
/ York Rake and the BX #6
Buy it. Use it.
If you have difficulty pulling it often enough to matter, just cut 6 inches off each end. Or remove the end tines, if you don't have frame width clearance issues.
Bruce
/ York Rake and the BX #7
$600 is a steal for that rake. The blade might be a bit too wide for your BX but the rake should work fine.
/ York Rake and the BX #8
Jeff, What is that white bottle on your rops? Philip.
/ York Rake and the BX #9
It is a piece of 3" Schedule 40 PVC with a 3" cap. It is attached to rear hydraulic frame with a carriage bolt + nut and a cable tie.
It is a heavy duty water bottle holder. Cap is not glued, just friction fit, so holder can be cleaned once in awhile.
http://www.tractorbynet.com/forums/attachments/249361-york-rake-they-any-good.html
Tollster, does it look like the one in this old thread. I bought it and recently converted it to hydraulic angling. Use it for moving snow as well as raking.
It looks exactly like that one, I was looking at that thread last night as a matter of fact. I am hoping to pick it up tonight for 600. I have been cutting a driveway in all summer, so I think this may come in handy, perhaps I could use the blade for snow removal, starting at the top of a hill of course...LOL
You did some fine work on that and save yourself a fortune.
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
John Deere 6125R (A60462)
John Deere 6125R...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
Stainless Ice Maker (A61166)
Stainless Ice...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
