It is rated for 15.8 but my machine only puts out 11gpm. It should still turn 550rpms
What pressure is the motor rated for? I know some hydraulic motors are only rated to around 1200/1500 PSI and the high pressure motors are quite a bit more expensive. With a 1-1 gearbox is 550 RPM's enough? A brush cutter is a pretty heavy load on a machine. All the brush cutters made for skid steers require high flow and usually high H.P. hydraulics with higher pressure as well. I hope it works for you when it's finished.
