Homemade dingo brush cutter
/ Homemade dingo brush cutter #1
Msc2177
Blue ridge ga
Toro dingo tx425
I am building a 42" bush hog for my dingo tx425. It will have a 5.9 ci hydraulic motor
Going thru a 40 hp 1:1 gearbox.
A few more pics. I put hinges at the top of quick attach for mowing up slopes
/ Homemade dingo brush cutter #3
Cool! What hydraulic flow rate does the motor require?
/ Homemade dingo brush cutter #4
Pretty sweet so far. Are you going to have a pair of castors or skids at the front to limit the cut?
It is rated for 15.8 but my machine only puts out 11gpm. It should still turn 550rpms
/ Homemade dingo brush cutter #6
Looks great! I've never seen a mower on a Dingo or the like but it looks like a great idea. Just don't hit any yellow jackets.
I will put 3" flat bar along the bottom for skids. Not sure if I'll need the castors yet.
/ Homemade dingo brush cutter #8
Will you need to install a hyd. oil cooler for continuous operation?
I don't believe I'll need an extra cooler. A lot of dingo attachments are built for continuous use. It has a cooler now with an electric fan mounted to it.
/ Homemade dingo brush cutter #11
Thanks. I asked about the flow because I'd like to have one on the side of my MF. Maybe one day…
The motor I bought from amazon. It's built by dynamic. $179.00
/ Homemade dingo brush cutter #13
What pressure is the motor rated for? I know some hydraulic motors are only rated to around 1200/1500 PSI and the high pressure motors are quite a bit more expensive. With a 1-1 gearbox is 550 RPM's enough? A brush cutter is a pretty heavy load on a machine. All the brush cutters made for skid steers require high flow and usually high H.P. hydraulics with higher pressure as well. I hope it works for you when it's finished.
/ Homemade dingo brush cutter #14
I want to build a PTO brush cutter myself... nothing available second hand here in Holland so i'll have to build my own...
But first i have to finish many other maintenance and repair jobs... Let us know how it performs, i'll allways learn from it :)
The motor is rated for 2575psi. I converted a bush hog sq48 to hydraulic a few years ago. Using the same style motor mounted on a mini ex. It's been worked hard and never give any trouble
/ Homemade dingo brush cutter #16
I have a Brushmonster cutter on my skid steer that is designed for standard flow. It works fine.
image.jpgimage.jpgimage.jpgHere are a few more pics. I got the skids welded on. I also put in the reinforced plate to mount gearbox
/ Homemade dingo brush cutter #18
Nice project! I have thought about doing that in the last, never got to actually doing it though.
Btw...
11 gpm x 231 cu in/gallon / 5.9 cu in motor= 431 rpm with no losses.
/ Homemade dingo brush cutter #19
You are only turning 446 rpm using 11.4 and 5.9 cu i motor, and 1 : 1 gear box..
Don't believe that is enough rpm as most bush hogs are 1:1 to 2.5 ratio.
Close to 1000 motor rpm would be better.
Try and get about 12,000 to 14,000 fpm
/ Homemade dingo brush cutter #20
Very neat job on a very neat project, looking good!
2012 Honda Crosstour Hatchback (A66738)
2012 Honda...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2015 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2015 KOMATSU...
2010 CATERPILLAR 312D EXCAVATOR (A65056)
2010 CATERPILLAR...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
