Land plain blade height help
/ Land plain blade height help #1
john40981
Dalby QLD
Yanmar EF685 with 4in1 loader, Yanmar YM2700 with 4in1 loader, Fiat AT7C Dozer
Hi all, this is my first post. I am very impressed with all the info that is given here, everyone seems very nice and helpful, great to see. I am in Australia, so Hi from down under.
I'm starting to build a land plain to make road ways on our 1000acre property but don't know what height to set the blades at. I intend to make the thing 6' wide and 8' long with 2 blades angled about 20deg left to right and about 2' apart. I will post some pic's of it as I build it.
Some advise about the cut depth of both blades would be a great help. I am not cutting hard packed gravel, our land is quite sandy and this is to tidy up and level the tracks after I push through with the dozer. I am thinking about half inch below skids for front blade and level with skids for back blade. Am I on the money??
/ Land plain blade height help #2
Hello and welcome! There is some great info on this web site!
I dont know anything about land plains but I have to ask... How in the heck did you get a goat to ride a dirt bike? :laughing: :drink:
Our goats are pretty cleaver here in QLD:thumbsup:
/ Land plain blade height help #4
I'm collecting material to make one with an adjustable front blade.
There are several methods used on commercial graders. I plan to weld the first blade to the end of a pair of trailing arms made of heavy plate. A front bolt will be the pivot, then at the rear near the blade will be several staggered holes to give a range of about an inch down to an inch above, with half inch intervals. This is to experiment with different settings. Sand, soft dirt, hard dirt, gravel, roads, fields, moisture levels may each need different settings. If I find one setting that is good for all, I can just leave it there.
Bruce
/ Land plain blade height help #5
When I made mine I laid the sides on the floor and raised the front about 1". The 1st cross was back aways from the front and it put it down about 3/4". 2nd one I would guess maybe 1/4". Then I put one stright across and if I remember right I think I raised it up about 1/4"off of the floor. I use mine on a gravel road and most of the time I the have to rase the front just a little.
/ Land plain blade height help #6
Both of my blades are down 1". I control the digging depth using a hydraulic top link. If you get into some hard ground, you will want both of those blades cutting. Can't do that very well if the back one is set flush. If I were you, I would set the blades at 30" apart. Mine are 24" and one of these days I intend to move the back one out so that they are 30' apart. Just seems like they might work better that way. don't know for sure though. :confused3:
Thanks for the super fast reply's. What's your thoughts on making the two blades angle different ways, one angled right one angled left to move the dirt one way then back again? I was thinking of doing it this way but it does require a lot of space. At 20 degree angle it will fit at 8' long but I have not seen any done like this, is that because it doesn't work?? or just because it require long sides to fit and most I have seen are not that long. I don't have any tight turns in any of the roads I intend to make so 8' length is OK. I was going to incorporate a 44gal drum on it's side on top of the frame over the blades to fill with water to give adjustable weight.
/ Land plain blade height help #8
Brian mine is longer then yours and if our road was like yours I think I would want all the blades 1" down. Right now with mine only down real close 3/4" I start popping big old rocks up. My angles on the 1st 2 or more. As long as I'm not popping up the big rocks it looks someone raked the road. Now this road is river run rock and some of the old base rock is big as a soft ball.
You said you use your top link to make it dig in. I can see how that would work good. I just couldn't do that with what I'm using it for.
/ Land plain blade height help #9
Love the goat rider (I think that came out right :D)
U can do a lot with that AT7 champ, but I know a little something to tidy up & smooth with makes it nicer. I have a tow behind the patrol land leveller similar to the previous post which is good (photos in the home made compact tractor thread) but I am in the process of building a land plane - which by my definition requires a set of wheels behind the blade & preferably with the blade roughly centred between the rear towing wheels and the trailing wheels.
There are plenty of ideas out there, but what I'm leaning towards in my design is a trailing axle that has adjustment in 3 axes with the vertical being hydraulic and able to do on the fly. Another axis allows tilt (in bulldozer language) another axis allows the axle to steer to lay the whole rear end off to one side to get into ditches (may need a bit of weight to stay over there unless the material is fines). Then the blade just needs to angle and various pitch changes would be handy also. Then you can utilise proper grading techniques and make decent crowns and ditches.
This link below gives a lot of good ideas for what is required
Trail'grader-The Portable Road Grader
/ Land plain blade height help #10
you man want to consider a box scraper, (it is adjustable, can move dirt short distances, and I have a very old John Deere version, great machine)
RB Box Scrapers, Pull-Behind Scrapers, Drag Scrapers the further back the wheel are the easer leveling is (line in the link for the grader).
I knew the guy that designed the box scraper in the web site, I posted. now made by another company,
I have made roads and maintained roads, moved and leveled truck loads of dirt, (you back the box up on the pile and pull it down), knocked off mounds and leveled, moved dirt/soil short distances, (few hundred yards).
/ Land plain blade height help #11
Is this the way you are talking about ??
Those pictures were taking before total completion . I welded 2 pieces of 3" x 3" x .25" angle stock some were around 15 to 20 degree angles about .75" above bottom of skids . Blades are then attached with 1/2" bolts , thus I can set blades from level with skids to a max cut of around 1.5" . Currently I have it set with front blade 3/4" down on that nearest side to camera while opposite side is maybe 1/4" down . Back blade is set 1/4" down on far side from camera while near side is actually above bottom of skid . I make one pass down driveway on 1 side , with side nearest camera against edge of driveway , then make pass back up on opposite side . I pull the shale from edge , bringing it back towards center then 2nd blade feathers it back towards edge of driveway without carrying it all the way back to edge .
I would say mine is 8' feet long without going out a measuring it , and it is around 7' wide , pulled behind a N.H. TC30 . Blades or just 6" x 1/2" flat stock .
Fred H.
Hi Fred,
Thanks for the reply, yes that's exactly what I am talking about. Are you happy with the way it moves dirt back and forth, would you change anything if you built it again. I was going to put a drum of water over the blades to give some more weight and a hinged Tail gate of sorts at the back that hangs straight against a stop to pull dirt with me if I needed or flap the gate over to hang back to drag across the dirt at the back to do a final flatten.
Yours looks great and looks like it would do a good job
Regards John
/ Land plain blade height help #13
For my needs , Yes I like the way the opposite angled blades work . As I described above , the crushed shale that we use on our driveway tends to migrate out to the edges , at least what is not packed down in the first month or two of grading . One thing that I would change , Which I am actually working on now , Is to put spacers or bushings on the bolts that hold the blades , Add vertical threaded rods to each side blade , which will be threaded through a fixed mount on top of each side rail , with a handle on top . Thus to change depth of blade on each side , it will be a simple situation of just turning the handle , moving that end of the blade to what ever depth I desire . In pictures above , I had to loosen all bolts , then slide blade to desired position and re-tighten bolts .I have seen graders / planes built with that type adjustment but some I seen had one handle which adjusted the entire blade were I want to adjust each end of blade differently . I have added more bracing from top of 3 point frame to back corners of side rails also , just have not taken any more pictures of grader since I first built it last summer .
Fred H.
/ Land plain blade height help #14
I have one of thesehttp://www.roadrunnerblade.com/index.html it works very well & the adjustable depth of cut is a must. I built one similar to the Roadrunner shown above but with the side plates & skid shoes moving rather than moving the blade assy. This will complicate a simple non adjustable build but it is worth it. My blade adjusts with a crank on each side from an 1" cut to about 4" above ground. This is for spreading piles of dumped material.
/ Land plain blade height help #15
John, are you going to used curved cutting edges?
I really like your LP Rusty Iron.
/ Land plain blade height help #16
Here's a link to Land Prides manual. If you look at the parts break down you can see how they do it. The blades are on a inner frame (#5) that has slotted holes. I think it has a range of 1" below the outer frame to a 1/2" above. If I was going to make one I would make the blades adjustable. Depending on how wet or dry your surface is will determine how high or low you set your blades. Also depending how heavy you plan on making it will also determine what height to set the blades at. When in loose gravel the extra weight will push the skids deeper into the gravel and will move too much gravel.
http://www.landpride.com/ari/attach/lp/public/manuals/303-230p.pdf
/ Land plain blade height help #17
Hi John,
I have no advice on, making a grader, but thanks for asking the question, because now I hafe even more information for when I do get around to making one.
Also I have to ask:
What are: a 5' "slasher blade", a "Jibb", and a "tree pusher"?
Thanks and G'Day,
Thomas
/ Land plain blade height help #18
Rustyiron, your build really caught my eye a while back - so when I finally find that "tuit" (round, of course ;) ) I'll be "borrowing" heavily from your ideas.
Thank you for all the pix, now if you'd just send me your Ironworker... :D
For others, to save searching
http://www.tractorbynet.com/forums/build-yourself/204355-road-grader-blade-progressing-pics.html
http://www.tractorbynet.com/forums/build-yourself/204942-road-grader-blade-add-3pt.html
http://www.tractorbynet.com/forums/build-yourself/202502-angle-grader-help.html
I know this is a pretty involved build, but after trying to get good results with my box blade I think it'll be worth the effort... Steve
/ Land plain blade height help #19
What is the extra parts braced up on the rear and do you have more photos?
I think bukitcase answered my question with his first link. Looks to be a skid steer attachment to be used as a pusher.
/ Land plain blade height help #20
Dragalong
I do like your land leveller Fred - the one i bulit was a quick knockup out of stuff lying around and is still a work in progress. What i like about yours is the way you say it takes the material over to one side to create a crown, handy having the adjustable cutters for depth & angle. The only thing i don't like on most 3 pt hitch attached levellers is that (unless I'm missing something) they stay fairly rigidly set (even like the berends one below is fairly rigid, but maybe float mode & a deft hand on a hydraulic top link would cover it) so when you transition between grades (i.e. lumps & hollows) that you want smooth transitions for they either lift off the ground or dig in - I know you can try & feather the lift height etc but thats why I like the tow behind (set & go).
Here is a couple of pics of the work in progess Dragalong - some are while upside down when it was getting teeth & one is when it was using a bridle before it got the adjustable towbar (the front sleeve of it is a little bent after hitting a stump but I expected an issue with it because it was only thin wall stuff that was on hand at the time).
It is destined to get a set of wheels on the back mainly to lift to travel or reverse & maybe some slots in the front I beam to allow material thru & maybe some fingers that allow bigger rocks to go up over into the box to be able to deposit them somewhere else. As heavy as it is, more weight would be good (the wheels on back will help towards that) - one time when it had the bridle on, it hit a rock while going downhill and it flipped in the direction of travel - was like hitting a tree for a split second then seeing in the rear vision mirror this thing chasing me down the hill. The old patrol tows it ok but if its full of gravel going uphill when its slightly wet gets to be too much. When it gets extra weight with the wheels etc it might become a tractor or dozer job to tow it but at least with the hydraulic or electric actuated lift wheels i could release the load when it bites off too much.
Anyway - a lot of good ideas in one place I reckon too.
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
1980 Great Dane 102'x48' Lowboy (A64912)
1980 Great Dane...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
2017 John Deere XUV825M S4 (A64912)
2017 John Deere...
