Worn or done for
/ Worn or done for #1
catdozer
john deere
Saw this on a 4330 kubota, wow was this thing ever beat on. All the pins looked like this on the tractor.
So ya just thought I would share this.
/ Worn or done for
What did the rest of the tractor look like ?
As good as the paint in the picture. When the guy was going across the yard, the cab would rock side to side cause it was rotted off.
/ Worn or done for #4
That poor thing are far past the point where the grease gun will a effect:shocked:
/ Worn or done for #6
It seems that he is just trying to get his moneys worth out of it.
/ Worn or done for #7
A couple of pumps with the grease gun will fix that right up.:laughing:
/ Worn or done for #8
That looks just like my backhoe I had. Yet mine was a 1960''s Deere that looked like that when I got it.
/ Worn or done for #9
The fact that the tractor is still moving under it's own power is amazing.
/ Worn or done for #11
Gives a new meaning to the word "slop". Worth its weight in scrap?
/ Worn or done for #13
I've actually seen worse. One of my old bosses bought an old ford TLB that was a lot worse than the one pictured. He rebuilt it himself, with a lot of time and money, but he is still using it 20 years later.
It's just a machine. Any of them can be fixed.
/ Worn or done for #15
For the right price it wouldn't be too bad. New pins, and re-line or build up weld and re-drill.
/ Worn or done for #16
I've seen worse , The loader i use everyday is that bad :)
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
