Piranha tooth bar!!!
/ Piranha tooth bar!!! #101
Harry, Thank you for the Piranha bar for my BX. Very prompt service and delivery. I installed it today and wasted no time exercising the new implement. I have been very skeptical and have watched this since it came out 1-2 years ago.
I must say it made quite and improvement in the ability of my BX to cut into a shale pile, scratch back rocky surfacing, remove small saplings and laurel, and enhance the ability of getting a full bucket of dirt and shale.
One note worth mentioning as Maestro said, it does require removal to use with the Bro-tek brush forks as the bracket assembly interferes with the brush forks seating in the bottom of the bucket.
Thanks again Harry, it's a very well thought out design and it shows.
~Tol
/ Piranha tooth bar!!! #102
Just ordered one. Can anyone tell me what size hole needs to be drilled for the attachment bolts?
/ Piranha tooth bar!!! #103
Deezler. Your point is well taken that the ability to penetrate the ground is (somewhat, not the only factor) relative to the contact area. The large teeth on the Piranha serve the major function of penetrating and disturbing the earth. You probably don't realize that the teeth are slightly narrower than the traditional teeth, making the actual contact area of the 8 teeth on the Piranha roughly the same area as 6 conventional teeth. BTW, That was not an accident.
The teeth on a conventional bar are spaced pretty far apart. Any dirt not broken in the area between the teeth, now hits the straight edge of the bucket. The small, sharp teeth on the Piranha penetrate this dirt and fracture it as well. Of particular note, any area with roots, etc. is much more easily cut. One of the many test prototypes actually had the small teeth omitted. Another had longer teeth. Longer teeth significantly reduce breakout force (important when clearing brush) as well as made it more difficult to cut level grade. We used the combinations that gave us the best overall results in building an effective and versatile attachment. The Piranha does much more than just dig.
It was immediately obvious, is that any tooth bar drastically improves the loader's digging performance. Also obvious, the ground being manipulated and the operator's technique made far more difference in digging than did the type of tooth bar.
Cheers!
Harry
You have definitely sold me, you make a lot of sense. I will be ordering one this week for my B26 if the shipping cost isn't too much. Ttys, thanks
/ Piranha tooth bar!!! #104
I think it's 3/4. Just buy a 'step' drill bit. I borrowed my neighbors and had the holes drilled in 1 minute.
/ Piranha tooth bar!!! #106
Yep 3/4" it was easier to drill than I expected. A step drill is your best bet.
/ Piranha tooth bar!!! #107
I couldn't find a step drill bit @ Home Depot, so I just got a 3/4" bit.
It was harder to prevent it from walking than a step bit, but still worked well. The bucket steel is not super hard.
/ Piranha tooth bar!!! #108
/edit -
And to anyone - How well do you think the Pirahna would work for digging up bamboo "stumps"?
My present bamboo clearing method is to trim them down to 2" high then back over them with a 5' rototiller. I can't drive over them for fear of puncturing tires.
I would think it would be not too difficult. I would attack right at ground level (as low as possible) and go right at it. Too high up and things will push over rather than shear off.
I think keeping traction will be the biggest impediment, depending on your tractor.
/ Piranha tooth bar!!! #109
What deezler said! Sorry Harry, no offence intended, but I was rather disappointed with my Piranha tooth bar. Make no mistake it is well made, but the tooth bar on my Johnny bucket cut better then the piranha does (although I had it on a GR and it didn't have enough power to make use of it). Right now I am trying to move a few tons of 1 to 3" river rock and it;s having a real hard time with that. That said, I am still perfecting my methods. It does seem, to work well for cutting underbrush close to the ground. I have considered cutting out the smaller teeth as well. However, it is infinitely better then no tooth bar at all : )
/ Piranha tooth bar!!! #110
My gravel guy told me that 9x12s would stop his huge front end loader in its tracks. Nothing does well with loading big rocks from a pile. Thats what grapples are for. I think the piranha is a great compromise just as our tractors are.
/ Piranha tooth bar!!! #111
Well I don't load my tires but I can hook up my chipper for another 800lbs easily for more traction.
/ Piranha tooth bar!!! #112
Trying not to hijack the thread but get more info I think many of us would like -
Harry - Many of us have clamp on tooth bars. I've seem to remember at least one poster (don't know where the post is) who successfully installed a set of clamp-on's over a Pirahna.
How difficult would it be for someone with tools like a 4 1/2" handheld grinder to cut off a couple of the small teeth of their choosing for a custom spacing of the clamp-ons?
Basically how hard is the metal?
/edit -
Hi Mr. Newbury,
I am the member who uses my forks over the PTB.
We have forks from the Yankee Warehouse, and while they fit well in the flat gap where the teeth were left off, but we also frequently run into narrow pallets and so one day on a whim, I put the forks onto one (well 2 actually) of the small teeth and they fit pretty well.
To be honest, we did have to modify the fork mounts when the tooth bar arrived, but all that entailed was to cut a groove (using a narrow cutting wheel on my cheap HF angle grinder) into the holders for the 2x4's intended to prevent roll back, and then trimming a corner off the bottom of the 2-by's.
I think you will find that the PTB works well for the bamboo stumps, but it may be even easier to use it to uproot them BEFORE/instead of cutting them off, because then the upper part of the plant will keep the roots under tension as you cut under.
Have you ever tried to cut string, always much easier when you hold the ends and keep it under tension.....
YMMV, but I think you'll find the PTB an excellent addition to your property maintenance arsenal.
Thomas
PS: I also highly recommend the Yankee Warehouse forks, (oh, and mine are chain-on, not clamp on.)
/ Piranha tooth bar!!! #113
That's a big tractor :)
Actually makes me wonder if there is an ideal size for using a PTB... It seems most of the PTBs are used on the smaller tractors that may have limited options or power.
I wonder if you get beyond a certain size that the uses us guys on the compacts are talking about don't apply as well to the big machines..
/ Piranha tooth bar!!! #114
I added a Markham toothbar to my BX23 plus foamed-filled the rear tires and bumped the Hydraulic Pressure to the high limit of spec.
Really made a difference and ability and capability.
Most recent project has been transforming a crawl space to usable space and the BX just makes the grade.
No problem fitting my clamp-on forks over the toothbar.
/ Piranha tooth bar!!! #116
Re: Piranha tooth bar using with forks?
When Harry first came out with the Piranha and announced it on TBN there was some discussion about using his forks with it installed. The two "missing teeth" areas are indeed intended as spots for his forks. Harry has clarified that you can order the notches in different locations, or not have any notches at all.
I just ordered a bar before I read your post and noticed the "missing teeth" as you described. Sent a message to them with my order number to ask to have my TB with all of it's teeth installed. Thanks for pointing that out.
Edit: Received notice from BXpanded they will make mine without the quick-on fork cutouts. Pretty quick response!
/ Piranha tooth bar!!! #117
I have had my Pirannah tooth bar for several years.....never take it off....use it for clearing and light digging. My forks fit right over the teeth.....no problem. This is a very good...well made product.
/ Piranha tooth bar!!! #118
I have no complaints with the one on my BX 24 , I am going to order one for my New holland 1925
/ Piranha tooth bar!!! #119
Ordered at PTB from Harry late last week for our LS XR4046HC with 72" bucket, and it should arrive at Ranch tomorrow. I'm anxious to get it installed and start using it this weekend.
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
M&W 4500 Round Baler (A65579)
M&W 4500 Round...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
