I Just Got a New Air Compressor
/ I Just Got a New Air Compressor #11
It doesn't look to me like that motor CAN be reversed - all I see on the nameplate is the option of 110 or 220 volt hookup. You're right about the age - I haven't seen 110 instead of 115 or 120 on a nameplate for about the last 45 years or so.
Only way I can think of that might get you by is REALLY rube goldberg - you'd need to fab a mount that would hang the motor out the BACK side of the compressor motor mounting rails, and flop the motor around so it's driving the air pump from the opposite side.
When the motor went out on my compressor, I found the exact same 5 horse Baldor anywhere from the price in the posted link, all the way up to $1000. Those motors have a terminal box on one side that's about 4" x 6" by 2" deep - the cover plate on it lists strapping for 120, 240, CW and CCW options. It also has double capacitors that I think may enter in to the direction choice, don't recall now (I was just happy to have air again :=)
Wish I could offer more help, but I know you don't want MY "extra" 5 horse - all THOSE horses aren't even worth makin' dog food out of any more... Steve
Oh, switching the two AC wires won't change anything - you either wire it for 110 or 220. Doesn't matter whether (for 110) the neutral or the hot goes to L1 or L2. For 220, L1 and L2 are both hot. In either case, your power cord should have its green wire hard wired to a lug on the motor FRAME.
You might want to double check that the frame is NOT tied to either pair for 110 operation - I'm not sure about some of the older stuff having both L1 and L2 isolated. An Ohm meter will let you know for sure - you want NO continuity between ground (frame) and EITHER L1 or L2.
Hope this helps...
I agree that there is not an easy way to reverse this old motor. I'm convinced, though, that somehow it can be reversed.
The point may be moot now, though. I found a 5 hp single phase motor at work sitting on a shelf in the back all covered with dust. I've talked with the powers that be about making some kind of trade with what I have. It sounds like I'll probably be able to work something out.
New question... If I can get this 5 hp motor how do I determine what size of pulley to put on it?
Wouldn't it be easier to just get a single phase to 3 phase converter and use the exsisting motor? Surplus Center has them Surplus Center - 1 HP TO 3 HP PHASE CONVERTER
Or you can find them on CL fairly cheap.
Well, for that matter I can induce a phase in the existing motor with a couple of large capacitors. I figure if I am going to buy anything, I want to try first to get a larger motor. Then, if that doesn't work, I will look into other options. I figure if I am going to take up shop space with a 5 1/2 foot long air tank, I might as well maximize how much air I can get.
/ I Just Got a New Air Compressor #16
Here's a link to an IR 2340, looks like just a newer version - shows specs INCLUDING motor rpm, pump rpm, pully (sheave) sizes, etc - should get you close, although you didn't mention whether the motor you're lusting after is 1725 rpm or 3650 -
INGERSOLL-RAND Air Compressor Pump, 2 Stage - Air Compressor Pumps - 4KR37|2340 - Grainger Industrial Supply
Mine has taper locks on the motor sheave, if you're not familiar with them you may need to "cut and try" a couple times to get the two pulleys co-planar for best belt life... Steve
/ I Just Got a New Air Compressor #18
A compressor pump doesn't care what direction it turns BUT the flywheel has a fan for cooling and oil system might not work properly.
If you change oil in the pump make sure you use 30W NON-DETERGENT. Walmart sells it, also NAPA.
Thanks BukitCase for the Grainger link. That's VERY helpful. Those specs are exactly what I've been looking for. I'm especially interested in the max RPM and max psi specs. For a speed of 1745 rpm I'll need a pulley that's over 8". That's a big pulley.
The motor I'm trying to get is a 1740 rpm motor. The plant engineer needs to take a look at the motor tomorrow morning and make sure it's truly surplus and not waiting to be installed in some machine. Then it will be on permanent loan to me.
Stimw: I do plan to change the oil. That seems like a good idea for a used machine. Any other maintenance items that I should consider?
/ I Just Got a New Air Compressor #20
Those numbers didn't sound right, so I did my own math - with a motor speed of 1725, flywheel diameter of 13.75 and motor sheave diameter of 6-17/64 (all their numbers) you would get a pump speed of 786 rpm, NOT 1575.
My DevAir 5 horse (baldor, not toy) 80 gallon upright compressor has a motor sheave that's about 6-7 inches and a flywheel that's around 16 inches (too lazy to go measure them) which would put the pump speed at around 700 rpm, and it puts out 19-20 cfm @ 175 psi - I'm guessing the DeVilbis pump must have a different bore and stroke, but SOMETHING's not adding up here -
I think the reason your old motor sheave is so much smaller is so the smaller motor can drive that pump, but the discrepancy in Grainger's numbers bothers me.
One thing's for sure - if you go with the 5 horse, you're most likely gonna need to fab a new belt guard once you've got it dialed in... Steve
2006 CATERPILLAR D6N CRAWLER DOZER (A62129)
2006 CATERPILLAR...
6 New Sealed Apple Ipads (A59317)
6 New Sealed Apple...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2013 FORD F250 (A60460)
2013 FORD F250...
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
