Well...
/ Well... #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
I spent my day off trenching and replacing the drain line at my Dad's place. The bottom of the hill was a bit wetter than I anticipated. Things were fine trenching down the hill. The attempt to back up the hill was far less successful. Mud under the high grass. Wet, red, clay mud. I cussed. A lot. I felt better but the tractor is still just as stuck. Seriously stuck. Crap.
/ Well... #2
Not to make fun of your predicament, but that is not stuck.. that is not even close to being stuck.. you are "detained". I don't see any sunken wheels, and no frame parts on the ground. Did you try to use your loader to push your self backwards uphill? Did you get any material to put under the tires? Did you get out the come-a-Long? You are going to have to get to work to get that machine really stuck..It is a long way from being stuck. You might just be able to turn it around and get the weight on the rear wheels and put some boards under them to get a little momentum start and just drive it up. You can also try to clean the mud off a bit to get a little start bite maybe too. Keep at it,. Maybe you can get it stuck, but you are not stuck yet.
James K0UA
/ Well... #3
You'll have her movin tomorrow.
/ Well...
A bit of an update. I am now wedged against a tree. I think I will be recruiting my neighbor and his big orange M8560 tomorrow. They are cranking up their haying in the field adjacent to my place. I just hate asking...
/ Well...
James K0UA
I like that..."detained."
/ Well... #6
I got my first tractor (many years ago) stuck after I had owned it about 2 weeks. Now I was stuck mind you. I had both front wheels down below ground level and and pushed down into the mud many objects including a sheet of roofing tin, many bricks and rocks and boards. The FEL just would not push anything.. And I did not have sense enough to get it out. I did the "walk of shame" to the neighbor and asked for his help. He seemed very calm and inquired if I still had my Ford Explorer and a cable or chain. I said yes and he walked over. He asked that I get in the Ford at 90 degrees to the tractor, which allowed a downhill pull on pretty solid ground. He got on the tractor and fired her up. stomped the right brake to the floor turned the wheel hard over starboard (to the right) and popped the clutch as I pulled a bit with the Ford, The tractor "screwed" itself out of the ground almost instantly and was free. I felt like an idiot, as the wife and I could have done that. But I never forgot it.
James K0UA
/ Well... #7
Invest in a "Wyeth-Scott" Power Puller hand winch and the amount of time you are "detained" will become much smaller.
/ Well... #8
Greg,
I agree with Kuoa. However, if you keep zooming around there, without a plan, you could go from "detained" to really stuck. Stuck starts when the tractor is resting on the frame and all four wheels spin somewhat independently and freely.
/ Well... #9
Greg, I would not ask the neighbor, you know how people are in Mac...Dowell county. They will put signs up in town and make fun of you.:eek::eek:
Sell it, sell it where it sits!! :D:D
Can you get a truck close enough to put a chain on it?
/ Well... #10
Aw 'cmon are they really that mean in McDowell County?:)
/ Well... #11
Amen! I bought one last Fall...incredibly well built. I went with the Amsteel Blue rope for a bit more protection from flying cables.
/ Well... #15
yeah, that is looking like stuck. And there is a nice implement on the 3pt to help matters:D
That is about how stuck my Bobcat was the first week I had it.
I got the GMC and pulled it out fairly easily, just had to enroll the assistance of the neighbor to drive out the tractor
I have come close a few more times, but with learning how to use the FEL I have been able to get her out on her own power
/ Well... #16
I have been told there is two kinds of tractors. Those that are stuck and those looking for a place to get stuck!
/ Well... #17
Got mine detained with the frame on the ground and all four wheels spinning. Used a shovel and boards to get it out.
/ Well... #18
I've had my older JD855 "detained" twice. Once each last winter and the one before.
Each time I carelessly got the right front wheel off into the ditch. And hung it up on the frame that holds the pto and mounts the snow blower lift.
Luckily both times I had the good sense to be going slow and not get myself into more trouble than just that......
A little help with a tug from my pickup with chains on, and I was out and going again.......
Not near as dramatic as the circumstances in some of the incidents posted......
Keep safe....
/ Well...
Greg,
Did you get it out?
David
Not yet. I am gonna get one of the neighbors to help me tomorrow morning. We've had another thunderstorm this afternoon so I had to call it a day. I am hoping he can skid the back end out enough to clear the tree it's wedged against to save me from crawling under the tractor with a chainsaw and making a bigger mess!
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
2006 MACK GRANITE CV713 DUMP TRUCK (A65057)
2006 MACK GRANITE...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
X (A68191)
X (A68191)
2009 International 4300 Box Truck 24' (A62613)
2009 International...
10ft Fork Extensions (A66734)
10ft Fork...
