Kubota L4330 - Loader bolts missing / threads mashed / stripped threads
/ Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #41
Larger bolt needs greater torque in order to apply equal clamping force.
/ Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #42
It is a known fact that the loader frame bolts need to be checked routinely when the rig is new. I believe it is mentioned in the owner's manual.
Ahhhhhhh.....maybe the factory knows something. My B3300SU seems to vibrate a bit too. I check the FEL connections to the tractor frame every ten hours, when I grease it.
Does anyone know the Kubota stated torque specifiation for the FEL bolts????????
/ Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #44
Gr10.9 fine thread 16mm should be about 200ft# dry. 18mm fine about 260. About 210-215 on the 18mm should give near the same clamp force as 200 on the 16mm.
larry
Thanks - I choose a FTLB close to that, I was nervous about ripping out the cast iron threads plus hand re-tapping the holes did not provide the same precision of taping as the factory did with fixtures. I used a very good loctite meant for zinc coated bolts - let's hope they don't loosen up again!
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL4DL295841 (A61165)
INOP/NON-RUNNING...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
New Holland Work Master 75 Tractor (A61166)
New Holland Work...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61567)
2024 Kubota...
