BX25D - Traversing a slope for mowing... max?
   / BX25D - Traversing a slope for mowing... max? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay folks, I have an acre of sloped property. Some have already seen a bit of what I am dealing with but here is another question. I am planning to terrace as necessary using Allen Block, trying to limit my steps (wall heights) to 4ft and I want to gently slope the areas between the steps so that it is comfortable to mow traversing the slope. The big question is what is the degree or percent slope you recommend for this using my BX25D and a 60in MMM? I installed the BroTek wheel spacers. Please make sure you specify whether you are talking degrees or %slope! I guess in more simple terms, what angle should I feel comfortable driving my BX across??? First pic actually might not do the slope justice. Second pic looking up from the bottom and giving you an idea of the debris field I am beginning with.
   / BX25D - Traversing a slope for mowing... max? #2
I have a BX2360, 60" MMM and 2" spacers .. feels safe to me going sideways across 25 degrees.
Okay... added some pics (edited original post). Just installed a free app for my iPhone today called Tiltmeter. I mounted it to the top of the engine cover of my BX using a windshield suction cup and calibrated it to level. Seems pretty accurate (at least for this exercise) but the vibration of the engine makes the reading not steady. Need to either turn off the engine or come up with a way to dampen the vibration.
Oh, I forgot to say... Wow 25 degrees still seems scary to me! :eek:
   / BX25D - Traversing a slope for mowing... max? #4
Nice pics .. I replied too soon lol .. I reckon I could go across that cleared area no probs. Here is a pic of mine at 22degrees. Have used it on steeper hills but I think 25 degrees would be my safe limit
   / BX25D - Traversing a slope for mowing... max? #5
I was a heavy equipment operator for many years and I kept all our equipment as level as I could at all times while operating.
I would never use a dozer sideways because they could side sideways. I wouldn't mow sideways either if I could simply go up and down the hill to mow. Yes it's a pain to do it that way but It's SAFE. Get rid of the tilt meter or app. I'm sorry if I'm about to hurt anyone's feeling but tilt meters are nothing but a gadget on a tractor. there great on a crane or boom truck but not on a tractor. You'll spend more time looking at them and loosing consentration on the work ahead of you.
Instead of using a tilt meter use what I call my comfort zone sensor. It's built into you. Everyone has one. If your doing something and it don't feel comfortable or right then its probably not and DON'T DO IT.
These machines can do a lot of work and your off to a great start but please be safe. If your going to be "out of level" put on your seat belt. The safest place to be in a rollover is in the machine. Never try and jump clear and keep telling yourself this until its etched in your mind.
Glad your enjoying your new machine but please be safe.
Cheers. Paul
   / BX25D - Traversing a slope for mowing... max? #6
I'd agree with Paul. The tilt meter is interesting, but only from after-the-fact. Your pucker factor will tell you more than anything else.
So, first, get rid of the FEL and backhoe in order to mow. The FEL will transfer several hundred pounds off the solid rear axle onto the rocky front axle. Not good. I gotta believe the hoe is too top heavy, though I don't have one. I can ride my BX w/o spacers on a 25 degree slope pretty easily, though I go really slow. The first part of your yard looks WAY more steep than that, just below the deck. I can't imagine mowing that at all. :eek: Obviously you are mowing it now, but I don't know what you are using to do it.The rest of this property doesn't look too bad to me, but I would go up and down for most of it if I could. That's just being smart. I'll be interested to see what you end up with there. Right now the rocks might make mowing an expensive exercise.
   / BX25D - Traversing a slope for mowing... max? #7
When I worked at a little nine hole golf course, the back side of two of the greens were about like your hill. What I did was to go straight down with the tractor in a lower gear. The first couple of times will raise your heart rate, but as long as you keep it going straight down the hill, it is safe. Like 4shorts and RaydaKub said, wear your seat belt and take off as much weight as you can. And remember it doesn't have to be mowed as often as the rest of your property. You might think about using a good bush hog until you get it into better shape. That is what we did on the steepest slopes. With the rear wheel off, you can mow pretty close with it. It just takes a little practice handling the lift. Good luck.
Cheers. Paul
Thanks for chiming in Paul! Agreed the tiltmeter is just a fun free app I installed for curiosity. The pucker factor is there regardless. My main purpose was just to get a 'feel' for the slope that I want to grade. The reason I want/need to mow sideways is because the distance between the tiers will be very short (two mower passes probably) but a 100ft in the sideways direction. I may end up doing it all with a push mower if I can't design it right.
Thanks for the comments, Kay, Yes if I do end up with a MMM (depending on what I can actually grade appropriately) I would remove the FEL and BH. Long ways from that point... lots of dirt work to do first.
You are correct, the upper part of the hill next to house is way too steep to mow. I have to use a weedwacker and that is what I am trying to avoid. It is treacherous. I surely don't want to add any more lawn that requires that kind of maintenance. I have a great Honda self propelled push mower that works great and use it for other areas and that might just get more business if I can't landscape the lower area with enough gradual slopes and terraces that allow a MMM to navigate.
   / BX25D - Traversing a slope for mowing... max? #10
As Paul said...Up & Down ...no sideways...stay safe...if you slide and the downhill wheels catch a rock or depression , you are going over...not worth the chance...Stay safe
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
