water pump leak
/ water pump leak #1
millerweld
oswego ny
mahindra max 28 tlb
hello everyone !!!!
New to the forum. I did a lot of research on this site before I bought my Mahindra Max 28 TLB package. Tractor has been bitter sweet. I done a couple jobs since I took delivery in March. However I had a loader valve leak and a bad bucket cylinder. Both were fixed under warranty. I used it for a few minutes the other day. Now I have antifreeze leaking from weep hole on water pump. I will be on the phone to dealer tomorrow. This tractor sat around for a while it was last years left over. I think this a result of that, I hope.
Looking forward to being a member on the the forum thanks
/ water pump leak #2
That's irritating but lean on your warranty and chances are you'll get all the bugs out before it costs you money. Welcome to the forum!
/ water pump leak
The mechanic stopped out to look at water pump. Should be picking it up tomorrow.
/ water pump leak #4
hello everyone !!!!
Welcome to TBN--join the fun:thumbsup:
I have a leaking water pump (shaft seal) on my 1951 Minneapolis Moline BF tractor that I'm restoring. Rebuilt that pump about 3 years ago. It sat on the shelf since then while I slowly moved ahead on the restoration. Installed the pump last week. Adjusted the belt tension. Bumped the starter a few times to check for belt wobble. Got fairly large leakage from the weep hole. I figure that the part of the pump casting on which the seal is located probably has some corrosion that's causing the leak. Found a rebuilt replacement on the Web for about $80. Should be here next week.
Good luck with your Mahindra.
/ water pump leak
water pump fixed:););) Dealer came and got tractor the day I left for vacation and it was in my yard the day I got back!!!!
/ water pump leak #6
Cool, glad to hear you got it fixed.
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
2001 International 4000 DT 466E (A60462)
2001 International...
2019 Kubota KX057-4 (A64126)
2019 Kubota...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
