water pump leak
/ water pump leak #1
millerweld
oswego ny
mahindra max 28 tlb
hello everyone !!!!
New to the forum. I did a lot of research on this site before I bought my Mahindra Max 28 TLB package. Tractor has been bitter sweet. I done a couple jobs since I took delivery in March. However I had a loader valve leak and a bad bucket cylinder. Both were fixed under warranty. I used it for a few minutes the other day. Now I have antifreeze leaking from weep hole on water pump. I will be on the phone to dealer tomorrow. This tractor sat around for a while it was last years left over. I think this a result of that, I hope.
Looking forward to being a member on the the forum thanks
/ water pump leak #2
That's irritating but lean on your warranty and chances are you'll get all the bugs out before it costs you money. Welcome to the forum!
/ water pump leak
The mechanic stopped out to look at water pump. Should be picking it up tomorrow.
/ water pump leak #4
hello everyone !!!!
Welcome to TBN--join the fun:thumbsup:
I have a leaking water pump (shaft seal) on my 1951 Minneapolis Moline BF tractor that I'm restoring. Rebuilt that pump about 3 years ago. It sat on the shelf since then while I slowly moved ahead on the restoration. Installed the pump last week. Adjusted the belt tension. Bumped the starter a few times to check for belt wobble. Got fairly large leakage from the weep hole. I figure that the part of the pump casting on which the seal is located probably has some corrosion that's causing the leak. Found a rebuilt replacement on the Web for about $80. Should be here next week.
Good luck with your Mahindra.
/ water pump leak
water pump fixed:););) Dealer came and got tractor the day I left for vacation and it was in my yard the day I got back!!!!
/ water pump leak #6
Cool, glad to hear you got it fixed.
2013 Ford Explorer SUV (A66738)
2013 Ford Explorer...
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2009 STEPHENS TRAILER (A67714)
2009 STEPHENS...
