Maximum Torque for 1/2" Drive Impact Sockets
/ Maximum Torque for 1/2" Drive Impact Sockets #1
Beltzington
Appling, Georgia
JD 3720
I'm sure there are variances between manufacturers but how many ft-lbs should you reasonably expect before the failure? If it matters I would like to use my 1/2" drive Kobalt socket with reducer and a 40" 3/4" breaker bar to remove my rotary cutter blades @ 550 Ft-lbs.
/ Maximum Torque for 1/2" Drive Impact Sockets #2
Any reasonable hex size - say 3/4 and up should take 1000 ftlb or more.
larry
/ Maximum Torque for 1/2" Drive Impact Sockets #3
Depends.
Some brands are better than others. Older Kobalt was Snapon (williams). Newer stuff isnt. All you can do is try it. May break. Then you get to check out their warranty
/ Maximum Torque for 1/2" Drive Impact Sockets #4
what size socket? The adapter may break before larger socket walls.
Don't know the socket size for sure which is one of the reasons I want to use my 1/2" drive set. My guess is the nut is 11/4". Mower is 50-miles from my house or I would find the size and buy the correct size 3/4" drive socket:). Breaking the 1/2" socket results in another 100-mile round trip.
/ Maximum Torque for 1/2" Drive Impact Sockets #6
1 1/4" socket, I think male 1/2" drive end of the adaptor is going to be your weak link for sure.
/ Maximum Torque for 1/2" Drive Impact Sockets #7
I agree, the adapter will most likely be the weak link., I use 3/4 drive for the larger nuts that are tight. I have also seen cheap 1/2 drive sockets shatter / explode so I use good impact sockets.
/ Maximum Torque for 1/2" Drive Impact Sockets #8
Coralate the cost to the source of manufacture and there may be be some indications of what's possible.:thumbsup:
/ Maximum Torque for 1/2" Drive Impact Sockets #9
Can you find out nut size from cutter manufacturer? I think there must be adapters that are impact strength? Autozone and maybe others loan tools for jobs- maybe a 3/4 " socket or set?
Agreed - Thinking back many years I broke a Craftsman 1/2 to 3/8 adapter beneath a 24" breaker bar. Appreciate all the input, we have had so much rain in the last 3-days I will not be mowing for awhile so I will have the opportunity to determine the nut size and buy the correct 3/4" socket and extension.
Crazyal - Thanks, great price on the sockets, just placed my order.
/ Maximum Torque for 1/2" Drive Impact Sockets #13
HF
Heaven Forbid
Also has 3/4" 6pt impact sockets which probably would be good for occasional use.
8 Piece 3/4 in. Drive SAE Impact Socket Set
Snag a 20% off coupon, and it will be even less.
http://images.harborfreight.com/hftweb/newhome11/images/20off912-aff17547.jpg
Are you sure the size is between 1" and 1.5", and USA Standard sizes (although with that big of a socket, you could probably fudge and use either standard or Metric on either bolt.
Do you have a plan to keep everything from turning? Wedging a board in somewhere?
/ Maximum Torque for 1/2" Drive Impact Sockets #14
Yep. That is exactly what happens to the 3/4 -1/2 adapters when excessive leverage is used. Your best bet is to find the right size 3/4 drive socket - - even better a 6 point impact 3/4 drive socket. . .:banghead:
/ Maximum Torque for 1/2" Drive Impact Sockets #15
How can you beat Ingersoll Rand brand sockets for cheaper than Harbor freight price. I have an adapter so I can use a 1/2" ratchet. I use a 3/4" breaker bar to get the bolt or nut loose then the 1/2" ratchet or impact to remove it.
/ Maximum Torque for 1/2" Drive Impact Sockets #16
Your weakest link may not be your tools, assuming you have reasonable quality tools.
I just sheared a 9/16" (hardened?) bolt using a 2' breaker bar and no cheaters.
You can generate some pretty wicked force with a 40" breaker bar. No doubt you could break a 5/8", or perhaps even larger bolt.
Double and triple check you are turning your nuts and bolts in the right direction.
MAN BASKET (A64553)
MAN BASKET (A64553)
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
Landhonor 8" Mini Excavator Bucket (A66285)
Landhonor 8" Mini...
PALLET OF WHEEL SPACERS & WEIGHTS (A64278)
PALLET OF WHEEL...
PAIR OF SPAN-ON RIMS (A64278)
PAIR OF SPAN-ON...
2022 EZ-GO ELITE...
