duckhunter27
Gold Member
I have a Z-Force 48 inch and I live in very sandy ground I mow atleast 2 acreas sometimes more most is just grass some is very weedy. I have been sharpening about twice a season.
The actual sharpening process is worthy of it's own thread, many options and many opinions!![]()
This is very true. I just bought new blades for my Gravely ZT. They are not what I would call sharp. I couldn't cut paper on the blades. Yet I know more than a few folks who insist finish blades need to be sharp enough to cut paper.
I have the high lift blades for the leaf bagger on my 3235 with 54 inch deck. About the time I think they should be sharpened I usually find that 1 or more of the "ears" have broken off and it's time for new blades. The first time there were 3 ears missing of the 6. I hope no one is around when one goes flying.imo these newer thinner blades don't hold an edge as long, so you sharpen them when to cut tips of the grass look frosty or ripped instead cut. For us that's every 3 or 4 weeks.
Aside from that I cut a lot of wet grass and a sharp blade makes that a whole lot easier.
Sharpening is pretty easy for me cause I modded our deck to cut closer to the ground. One of the mods was installing a few washers between the blade and spindle well that made it possible for me to use an angle grinder while the blades were still on the deck...
...yeah it's awkward and that move is best rehearsed first before powering up but it works.
My use to be neighbor use sand to fill up his wet holes and that helped a lot because then he could drive over that same wet area and not leave tracks...btw he used blow sand.
I tried that too and it works but we have a larger area plus I'm dragging cut trees across that same pasture so a perfect lawn is not our objective so much as a closely cropped lawn. It's a working lawn.
We hit golf balls out back and if you can't see them 150 yards away ...the pasture needs cutting.
That's why I cuss when I spot my air headed neighbor tooling around the yard on his rider cutting with the deck deflector pulled off.....I have the high lift blades for the leaf bagger on my 3235 with 54 inch deck. About the time I think they should be sharpened I usually find that 1 or more of the "ears" have broken off and it's time for new blades. The first time there were 3 ears missing of the 6. I hope no one is around when one goes flying.
Bob B.
Bob B.
Bob B.
The first ones were the original blades. The second set I bought at the IH/Case/Cub dealer for $75. The set I have now I bought from a Cub supplier on eBay and are still OK. These are the high-lift blades recommended for the triple bagger and have a 1" by 2" almost vertical ear on each end. They start wearing by forming a "V" where the bend starts on the ear (I think on the outer end) until it eventually cracks completely off.Bob, I've never heard this happening. What brand blades are you using that crack and fly apart? I have bent downwards a few but never had one fly apart. Do they do this without hitting something?
