Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 26,585
- Location
- The Last Red State in the Northeast
- Tractor
- Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
I need a cab, 4wd, FEL and a big (7+ foot) mower. I am looking at 40-50HP CUT's with a FEL to move 1000lb hay bales at my farm and a large mower to cut a couple estate size properties. Cut quality does not have to be stellar, just decent. Ground can be pretty steep, bumpy, certainly not a golf course. Grass may be let go fairly high at times with 2' high grass being entirely possible.
So bottom line is, can a toolcat 5610 with 90" finish mower handle that type of mowing? Can a toolcat load, unload 1,000 lb round bales into small trucks or trailers effectively? Is the toolcat pto/3pt legitimate? Could it handle smaller 3pt implements ok?
I currently do these chores with a small farm tractor and a 8' bush hog. It's too rough on the property when cutting. Other reason is that I need a 3rd tractor. Operations have expanded.
Or would I be better off with a 40-50 HP cut with a big (72-84") mmm and an FEL?
What I dislike about the CUT with big mmm is cleaning and sharpening middle blades. Also stability on steep ground. I'm assuming toolcat front mower is easier to maintain, but could be wrong. Assuming toolcat is stable on hills compared to CUT due to low center of gravity.
Thanks and sorry for all the ?'s, but it's a expensive decision.
