5000 series PTO question
/ 5000 series PTO question #1
corey9212
Red Deer County, AB
2015 John Deere 3046R
Hello, I was going to start spraying today and I had the tractor stopped and gear lever in park, range lever in neutral and direction lever in neutral as well, with the PTO running I get up out of the seat and before I could get out an alarm goes off, I quickly sit back down so the tractor won't quit on me.
Firstly is it possible to run the PTO without being in the seat?
Secondly if so then what am I doing wrong?
Thirdly I see there is a spot on the tractor where an external button could be installed to run the PTO when outside the tractor but I can't find any info on if an outside switch can be installed, if it can be does anyone know what part numbers they would be?
Thank you.
/ 5000 series PTO question #2
I don't think it will quit but the buzzer will sound the whole time you are out of the seat.
/ 5000 series PTO question #3
I think the spot is for a second set of buttons for your 3pt hitch.
JD has a kit for a fender PTO switches for 6x30 series tractors. It's AL180494. I think it has switches for both fenders and a rocker switch to switch from operator station PTO switch to fender PTO switches. Also you have to have tractor computer reprogramed,
I will have to give that a try next time, normal reaction for me it to plant my butt in the seat when I hear the buzzer thinking it would quit.
I have one spot that has 3 point controls and there is two spots that looks like a PTO control would attach to and another spot that looks like a right hand side hitch control would attach to.
I know on precious years there was a fender control for PTO and for three point and also for one of the rear SCV's (which would also be sweet for hooking up with a hydraulic top link. Here is a couple pics of those spots.
Here is a pic of what was available in earlier versions
/ 5000 series PTO question #6
Yes you do have the spots on your fenders. I was only thinking of the spot for the 3pt behind the tail light. Sorry for the misinformation.
I know the kit for 6030 series required software programming. It may be to bypass the seat switch? :confused3:
Maybe an earlier version will work?
So technician came out and took a look and agreed it shouldn't be stalling out, it was some sort if programming issue. Hooked it up to his laptop and a bit later it was working properly, it now beeps at me a couple times letting me know I'm off the seat then keeps on running.
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
JOHN DEERE 344H WHEEL LOADER (A63276)
JOHN DEERE 344H...
Bomag BW172 PDB-2 Compactor (A61166)
Bomag BW172 PDB-2...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
HAMM 2420D SMOOTH DRUM COMPACTOR (A62129)
HAMM 2420D SMOOTH...
