What is the best hand rake for this application?
/ What is the best hand rake for this application? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have need to rake the sides of about 500 yards of road to remove rocks so that I can mow without ruining my lawn mower blades. The rocks range from about 1/2" to 3" diameter. I have been using a traditional heavy rake for the job and its not really working out. Is there a rake that would be ideal for this application? thanks
/ What is the best hand rake for this application? #2
Something like this?
Rock Picker
1/2" is a pretty small I presume you could do quite well with a garden rake, but you may have problems with the smaller rocks.
Perhaps a fine tooth pitchfork would be better.
I could imagine building a small rock picker to tow behind an ATV or riding mower. It wouldn't have to be too complex, just relatively fine pitchfork teeth to snag the rocks.
/ What is the best hand rake for this application? #3
I hand rake but I only rake 800 feet. I have to clean up after the county goes by with their graders. Sometimes I rake more that 800 feet. Depends on how messy they are as I actually mow a 1/4 mile or one way so on both sides. Problem is traffic pops stones off the road and in to the grass. I toss rocks back when walking the dogs.
/ What is the best hand rake for this application? #4
Any chance you can raise your mower height ? Hand pick the biggest ones and throw them back onto the driveway.
That,s a long driveway. Do you have any children or grandchildren ? Have a contest, and see who can pick the most gravel.
/ What is the best hand rake for this application? #5
I just envy your nice flat road. I bush hog along the more open parts of my mile-long gravel drive, and don't worry about the rocks, just the stumps. My road is not flat. But in working grassy areas around the house, I find that stones continually work their way to the surface, so rock removal is a never-ending chore.
/ What is the best hand rake for this application? #6
What are you mowing with? Have you considered one of those walk behind string mowers?
/ What is the best hand rake for this application? #8
That's what I was going to recommend. :)
/ What is the best hand rake for this application? #9
What about a blade? If you set it an a long angle and adjust its engagement, it should scrape these rocks back onto the driveway or push them into the ground to where they will not be a problem for mower blades.
/ What is the best hand rake for this application? #10
could you rent a rock hound for the dayhttp://www.wikco.com/rhrake.html I used one when I was doing landscape work and the owner had built a house in the middle of an old shale pit. :( not fun but the rock hound help make things very easy.
/ What is the best hand rake for this application? #11
I use a rake like this for cleaning up 1/2 to 3 inch gravel. (let's see if the link goes through properly)
spin_prod_247657701
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A65563)
2019 Ford F-550...
