How Do You Fill Your Diesel Tank
/ How Do You Fill Your Diesel Tank #121
I doubt it, we have never had Draft horses. But it is possible since I have been to a lot of farm auctions.
They came out of the "small chain" drawer in my storage room.
There's little telling what you'll find at a farm sale.
/ How Do You Fill Your Diesel Tank #123
I use these: http://www.northerntool.com/images/product/images/27127_lg.jpg
They aren't cheap, but they don't leak. Takes ~5 minutes to empty one of the five gallon ones. I really like the rear handle.
I bought one of these after hearing all of the 'GREAT' reviews. Personally, I was a little disappointed, still have to push down spring loaded plunger. This is now my back up can.
My favorite is the standard yellow can with nozzle parts removed, and valve stem added to back.
Philip
/ How Do You Fill Your Diesel Tank #124
I have a 300 gallon tank in the barn with a 12V pump. Coop delivers....One of my best moves...
/ How Do You Fill Your Diesel Tank #125
Those are the same containers I like too. Our hardware store carries them. For years I filled them in town and then stood on the front tire balancing the fuel can on the hood while pouring it into the tank. Not a bad system, but there are better.
One day I got smart and bought a skinny little 12v submersible pump that is small enough diameter to slip into the opening of the fuel container. Now I no longer lift that can of fuel. Just sit it on the ground, hook the clamps to the battery, and the pump fills the tank jiffy quick.
When I'm done, the pump and hoses go back into a dedicated clean 5 gallon bucket with a lid.
No mess and no strain. The pump is a Rule brand; Amazon sells them. Check that the diameter fits through the opening in the plastic container.
rScotty
/ How Do You Fill Your Diesel Tank #126
Philip
I got tired of holding down the spring loaded plunger, drilled a hole in the plastic guards today, now I depress the plunger then slip a screw driver through the holes to hold the button down, effortless filling. :thumbsup:
/ How Do You Fill Your Diesel Tank #127
Philip
/ How Do You Fill Your Diesel Tank #128
I use a home-made siphon setup with an outboard primer bulb to get it started. Sit the can on the hood on a blanket, squeeze the bulb a few times, open a valve and wait for it to empty the can. Takes about 3 minutes for 5 gallons.
Sean
/ How Do You Fill Your Diesel Tank #129
Sean
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=321683"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=321684"/>
Great idea.
/ How Do You Fill Your Diesel Tank #130
I had a home made setup with 15 gallon container, Tuthill 12 volt pump, filter and service station type hose & nozzle when I had a Kubota B3030 with a 7 gallon tank. Now that I've got a Bobcat skid steer with 24 gallon tank, I just drive it to the corner convenience store and fill it a couple of times per year.
Sold the old pump setup as it had become excess baggage in the barn.
/ How Do You Fill Your Diesel Tank #131
Double post for some odd reason?
/ How Do You Fill Your Diesel Tank #132
I cut the top off a 5 gal water cooler jug to use as a funnel.
/ How Do You Fill Your Diesel Tank #133
Hey, now that is an idea! That makes a great funnel with a speedy drain.:thumbsup:
/ How Do You Fill Your Diesel Tank #136
You guys with the towels are so cute :).
ac
If only the paint didn't rub right off no towel would be needed :irked: Kubota should get smart and put some of that clear protective film in some areas, my FEL hoses have already rubbed through the paint on the side.
/ How Do You Fill Your Diesel Tank #137
My hood is so faded in only 3 years it is a joke. I realize at some point I'll be repainting it anyways.
Your idea is very smart. Why don't you just get some of your own clear protective stick on stuff and put it on?
ac
/ How Do You Fill Your Diesel Tank #138
Or just buy a DEERE and don't worry about it! Green paint doesn't rub off!!! :D:laughing::D
2016 John Deer 5075E (A60462)
2016 John Deer...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2014 Ford F-150 Pickup Truck (A59230)
2014 Ford F-150...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
