Gas or Diesel
/ Gas or Diesel #1
Pete6114
Gold Member
SW Ontario, Canada
F2690(Sold) GR2120(Sold) L3240(sold) B1700(sold)
I am considering a X700. Going today for a test drive to see how they handle on and across slopes. 4-whd but no 4-wheel steering.
Is gas or a Diesel engine better to have?
/ Gas or Diesel #2
Diesel is heavier and the fuel is more expensive. The diesel will last about 2 times longer than a comparable gas. Diesel will use about 1/2 the amount of fuel a gas does. Diesel has better torque. I have a diesel BX1500 and it is used as a lawn mower and I am impress at how well it powers a 54" mower deck even in thick grass. Diesel it is IMHO. :thumbsup:
/ Gas or Diesel #3
Below is my post on this. It will give you an idea of the fuel savings, present value (PV) of what your money is worth (US dollars) in 5 to 20 years and years to break even with a gas and a diesel engine. Based on my calculations with those set of variables and burning 55 to 70 gallons a year in fuel, the gas will be cheaper in the short term (5 to10 years), but if you keep the tractor for 15 to 20 years, the diesel will win out. However, the more fuel you burn a year, the better the diesel option becomes. I personally only burn about 55 gallons a year in fuel to cut the small areas of the lawn, but I still went with the diesel engine. My lawn can get very thick and wet in areas were the additional torque is needed. Hope this helps a little.
http://www.tractorbynet.com/forums/john-deere-buying-pricing/269681-diesel-vs-gas-x700-series.html
/ Gas or Diesel #4
I say forget the bean counting BS.
In this size of a machine, diesel is the best option. For a garden tractor these are heavy machines. Gas powered X7's drink fuel like a fish drinks water. While opting for a diesel version will increase your payment only slightly ($20 a month probably) you will notice the difference immediately. Resale value on a diesel is higher, regardless of whether you keep the machine short term or long term, the diesel WILL pay for itself.
Add EVERYTHING into the equation. Those who have calculated the fuel cost savings forget some important details. The more often you have to get fuel, gas, in this case, your spending money to get it. You have to get into your personal vehicle, drive to the gas station, buy the fuel, and return home. With a gas tractor, these trips will be VERY FREQUENT. Now, with a diesel X7, not only are you saving money on operating costs, but you will make very few trips to get diesel fuel. Saving wear and tear on your personal vehicle, saving you fuel in that vehicle, and giving you more time to accomplish useful things instead of making trips to the gas station.
Gas engines require more maintenance, such as spark plugs, on a regular basis. The diesel Yanmar engines are almost maintenance free besides oil changes and fuel filter changes. Besides that, you turn the key, and you go to work.
Once you go over the 20HP mark, and you get into the 1,000 + LB range, diesel is the only way to go. Gas engines will bog down in heavy thick grass. Diesel engines say "what's that?...did you feel something?...must have been a mosquito"
Please, do yourself a favor, and get a diesel engine. In this day and age, EVERYTHING should be diesel. They are extremely efficient, last forever, have gobs of power, and sip fuel.
/ Gas or Diesel #5
I just got the JD x758 AWD. Traded a gas 22 horse JD135 automatic on it. 1.5 acre yard with hill, on and off a slight bank. The 135 used about 3 gallon. The new JD X758. Needle didn't move. Darn happy with that. Its one fine machine.
/ Gas or Diesel #6
Diesel is better. Also get a set of HDAP tires for your slopes.
/ Gas or Diesel #7
I have an X728 gas and it does everything I have ever asked it to do without any loss of power. But JD tank is right that if you are going to finance the machine and you have a chance to get the diesel I would for sure. I bought myX728 at the end of the season and the dealer who had the machine on the show room floor made me an offer I could not resist so I took It. And I am happy with it no regrets. Although the tractor does eat fuel like my brother-in-law eating at a free buffet. I have thought of getting the new 1026 but I really love the X series tractors.
/ Gas or Diesel #8
A 2wd x7 will do outstanding on cross slopes. It will blow your mind how well and a 4wd only better. My preference is diesel no doubt, and 2wd with bar tires suits me well.
They didn't have 4wd when I bought my 455...
/ Gas or Diesel #9
I can testify to the amazing capabilities of the 2WD X7 series.
When I bought my X740 I was a little concerned about traction. I really have no use for AWD, and money was tight, but I knew I wanted a diesel. I scooped up the last X740 around and took my chances. All I can say is WOW! I have turf tires on my machine, which are not good for digging in and giving traction. This thing STILL pulls like a plow horse. The traction for a 2WD unit is nothing short of amazing.
The upside to the 2WD units is much easier transaxle maintenance. No bleeding air from the front axle and no jacking up the tractor to change the hydro oil. It boils down to less ownership cost if you truly do not need the AWD. When it comes time for me to start using the 54'' blade, I will have to compensate for traction with chains and weights. Still, it works great!
/ Gas or Diesel #10
Pete6114, I would say that it all depends on your property's terrain. My property is hilly and I can not tell you how many times I needed my 4wd even when just mowing. ( even with 70 lbs weights on each rear wheel) Also I have some areas that are wet and when I am pulling my manure cart to my compost pile the 4wd pulls me right through.
In short if your budget allows you get the 4wd and diesel you will be glad you did!
/ Gas or Diesel #11
I believe rboss75 summed it all up very well with that one sentence.
Is 4wd absolutely necessary? No
Is a diesel engine absolutely necessary? No
Is either one or both nice to have? Definitely!
/ Gas or Diesel
Thanks for your opinions. I am a guy that likes to buy the best, or buy nothing. So, while i'm buying the best in it's class (JD X700), i see a 4 WD Diesel in my future. I was quoted a price of 13,100 with a 54 inch deck on the X739 and 1600 for the hydraulic blade. Never talked about the premium deck yet.
I'll be getting a price for the X758 this week. I'll also call a couple of deer dealers across the border in MI for pricing.
Man...them deers are pricy!!!
/ Gas or Diesel #13
I see your from Canada. To put it bluntly, we get it up the poop shoot here.
Tractors here are always a few thousand dollars more than our southern brothers get them for. $1,600 for the blade/quick hitch sounds about right. My dealer in British Columbia quoted me $1,650 for that setup. Mutton Power Equipment in Indiana sells the blade, and quick hitch with hydraulic angle kit for $1,239! Maddening!
Purchasing an AWD machine adds about $1,800 to the cost. The diesel engine adds another $800 or so. So I wouldn't be surprised if you are quoted about $15,500 for the X758.
I signed the papers on my X740 in February as quick as I could. At that time John Deere had the $1,000 rebate on, and my dealership was trying to move old X7's to make way for 2013 models. In Canada, an X740 usually runs for about $13,000, or even $13,500. When it was done I walked away paying $10,000 for the tractor with the 54'' deck, and a bunch of freebie accessories thrown in. In Canada, that is an unheard of deal, I couldn't say no.
/ Gas or Diesel
I might be wrong, but i think i remember them saying, a diesel would add 1500 bucks. I'll find out on tuesday, when i get a quote.
/ Gas or Diesel #15
The argument of which is better diesel or gas has been going on since the diesels have been offered in GT's. The fact is gas engines will consume more fuel than a diesel about 1.1 gallons per hour vs about .9 gallons per hour for diesel but diesel cost more. There is no data that states that a diesel will last 2x as long as a gas engine, in fact my experience is that a gas engine will last as long, use the same fuel as my push mower and other equipment and be much easier to fix. The x700 gas engines are water cooled and most fuel injected, same as a diesel and I have yet to hear of one failing. We run both diesels and air cooled gas Kawasiki engines at work and have less problems with the gas engines. When the diesel do have a problem it is normally a more costly repair. I have also heard that diesels have more torque which is true but gas engines have more horsepower, but there is so little difference on these machines that you will not notice and believe me you will have plenty of both with either the diesel or gas. The diesel will cost about $1,000 more that the same gas model. Either gas or diesel x700 are great machines, but personally, I would rather spend my money on attachments. Either machine will most likely outlive it's owner if taken care of properly but most will get sold before that happens for something better.
/ Gas or Diesel #16
Well put Dashe,
And with these engines running a hydrostatic system which provide power to all your implements the idea of engine power loss under a heavy load is a moot point in my book provided The tractor is operated properly!.....
/ Gas or Diesel #17
Before you buy the diesel I would make sure I know what I'm getting into. Glow plugs, lots of additives, Auto Zone sells diesel additives by the pallet load. Fuel gelling, longer warms up with the engine shaking, cold weather is a problem for a lot of diesels.
Water separators, that's a whole different ballgame all by itself.
How about warming up a diesel in your attached garage, get ready for a smoke out. One guy wrote in he always has soot on the front of his x7 after blowing snow or mowing grass.
Diesel is always higher priced then gas, and don't forget the storage of diesel fuel, and how far do you have to go to get it.
There are a lot of things you need to know with a diesel, so if you want one study up on it.
Ever wonder why a city bus has the exhaust pipe up by the roof, you should be around one when they first fire it up and give it the old clean out, aw never mind.
Rob
/ Gas or Diesel #18
I almost forgot, if your going to get a diesel, you might want to do a little checking around your area on available diesel mechanics, sometimes they are hard to find a good one, then the prices they charge to work on one, that could be a little eye opener.
Parts and labor on a garden tractor versus a large farm tractor, well large farms deal in a lot of money, so getting a diesel mechanic for a garden tractor, more in likely he won't want to work on it versus the big tractors, its like getting one to commit to work on your rig for $300 or $400, that's another whole deal.
Check out who is available to work on it, you need to do the homework before you buy one.
Rob
/ Gas or Diesel #19
Before you buy the diesel I would make sure I know what I'm getting into. Glow plugs, lots of additives, Auto Zone sells diesel additives by the pallet t load. Fuel gelling, longer warms up with the engine shaking, cold weather is a problem for a lot of diesels.
Rob
You dealing with a Yanmar mini-max diesel engine here. The emission controls are a lot better on these engines so the "smoke out" issue is not there. You will not get the "engine shake" on this tractor due to the rubber isolator mounts Deere uses. Cold weather starting should not be a problem seeing that Deere tested this quite a bit especially when the tractor is kept in doors. Also, when the tractor is kept in doors and you use good fuel, water in diesel should not be an issue. If you use an additive like Power Service with your diesel fuel, gelling will not be a problem and gelling is even less of an issue if the the tractor is kept in doors. As for soot, yes it can be issue, but that is easily fixed by putting a piece of sheet metal on the front of the exhaust pipe to extend and deflect the soot from hitting the tractor. While diesel fuel is more expensive, the fuel gives you higher BTUs when burned versus gas, that why diesel is more efficient; gas will be even more inefficient if the ethanol content goes up - more ethanol equals less BTUs.
http://us.yanmar.com/products/industrial-engines/liquid-cooled/minimax/3tnm72/
/ Gas or Diesel #20
Well put Dashe,
Implements are NOT powered via hydrostat. They are direct driven.
Diesel is the way to go if you can swing the extra dollars...I have an X748, and will never go back to a gas garden tractor....ever.
