LINCOLN 225
/ LINCOLN 225 #41
Idealarc TM's are OK but I highly doubt you'll have enough power to run it unless you live in an industrial area. Most residential power is 100 amps. You won't need that much if you're burning smaller rods but it will still suck the power. I sure wouldn't want the power bill:hissyfit::shocked: It's also a huge machine that will be a real pain if you ever have to move it. Why are you so dead set against an inexpensive inverter? Although an Idealarc TM 400/400 welds nice enough, in this day and age it's a boat anchor, not just any boat anchor either. It could anchor the Oasis of the seas. I doubt any parts are available for it either. You're going from one extreme to the other and totally ignoring what would best suit your needs.
/ LINCOLN 225 #42
You can lead horses to water, but the drinking is another matter entirely.
/ LINCOLN 225 #44
I am far from an expert in any way on welding as Shield Arc can attest. However I am learning through his help. However having put forth that disclaimer I will say that anyone wanting to purchase a welding unit without breaking the bank should look at a very nice inverter which is the Stickweld 250.
It has been previously mentioned in this thread and the OP has discounted it. I believe that is/was a mistake.
It is a very nice unit with a very good duty cycle. No one has tried to pretend that it is US made or assembled but it is a welder that deserves a close look at for anyone considering an inverter who does not have a gold mine in their back yard. In addition it has a very nice response when used as a scratch start TIG power supply and you can get yourself set up for scratch start TIG quite inexpensively.
/ LINCOLN 225 #45
But some students make their teacher look really really good!;)
Some of your first vertical up with 7018 on the Stickweld 250.:thumbsup:
/ LINCOLN 225
I was about to buy an inverter. I contact Everlast for pricing and I got my answer in less than 15 min. :thumbsup:
Is been a week since I contact Longevity, 2 days ago they said that I will get my answer yesterday,
today still waiting.:thumbdown:
/ LINCOLN 225
500 I was about to pull the trigger for it
Got the Lincoln for half of the price
/ LINCOLN 225 #50
That's for a PA 300 amp or a 160sth with tig...PA 200 is half that...and less than half the power consumption. 200 amps is all most people will every weld at, including most professionals.
/ LINCOLN 225 #51
Which Everlast were you looking at? You'll pay the $250 difference in power in short order. I bet the Everlast could probably work on about a 30 amp breaker. I know a guy with a Dynasty 300 Miller inverter TIG welder. He used to have a Syncrowave 250. Both good machines. The Syncrowave would trip a 60 amp breaker. The Dynasty put out more amps, has way better arc control and will run all day on a 30 amp breaker. I shop I worked in went from 3 phase transformer welders to Miller XMT 304's. They were saving about $1000 a month on power per machine! They bought 14 XMT 304's with 60 series wire feeders. $14,000/month is a huge savings. I know this is in a commercial setting but comparing an inverter to the TM will still bring big savings. You may need heavier wiring for the TM in case you ever want to turn the amps up. Welding wise, the TM is a good machine though.
For home use or around the farm 200 amps is plenty. The AC 225/DC125 the OP was originally looking at is less than half of the DC rating of the PA 300. Personally, I like being able to burn 3/16" 7018 on bigger jobs but I have a lot of experience burning 3/16" and 1/4" 7018 on large skids and heavy pressure vessels and piping. Don't have much need for 1/4" on my own projects. It's a big difference going to 1/4" at 300+ amps.
/ LINCOLN 225 #52
I sincerely hope you are happy with your purchase, but I really think you have made the wrong decision here. It's not too late, though. If you paid $250 for the Idealarc, that's actually a decent deal, and you can probably get your money back out of it, or a little more, and put that into a more appropriate welder. There's simply no reason for a typical home/hobby weldor to need a 400 amp machine. Modern, inverter-based machines beat the pants off older, transformer-based machines in so many ways that it's hard to even articulate. But even if you are set on a transformer, the Idealarc seems like a poor choice, due to its size, weight, inefficiency, and difficulty hooking it up to a household circuit given its high current draw.
I'm curious: what kind of plug or hookup does the Idealarc have on the back? Since it may draw up to 128 amps, it seems like it can't be a standard 6-50.
/ LINCOLN 225 #53
I hard wired my Miller 330 A/BP welder into a 90-amp breaker. Plugs that size are outrageous in price!
/ LINCOLN 225 #54
Does anyone know if a 400 amp Idealarc is going to be set up for 3phase? Can it be rewired to run on 240 Volt 2 phase? This welder is getting out of the range of normal "home" welders I would think. Of course I know one guy that talked his power company into bringing 3 phase into his home. I guess it is doable.
James K0UA
/ LINCOLN 225 #55
That's a photo from an eBay listing of an Idealarc TM-400. It shows 128 amps input at 220 volts. That indicates to me that it's wired for single-phase.
/ LINCOLN 225 #57
This one shows 146 amps at 230 volts single phase, or 73 amps at 460 volts single phase..
I thought I was big-time because I have 200A service to my house. I could just about run that thing flat out. Just gotta get me a 150 amp square D.
/ LINCOLN 225 #59
"hey wifey, would you turn off the Air Conditioner, and water heater,? I am fixing to strike an arc!" :):) The largest breaker I have seen for my Siemens load center is 80 amps. and that is for the emergency heat when it is too cold for the heat pump to work..
/ LINCOLN 225 #60
TM's are single phase, that's why they draw so much power. I doubt the one listed will bring anywhere near $1300. Anyone with enough power would likely have 3 phase and pick up a used 3 phase for a few hundred bucks. I've seen Miller 400 amp 3 phase machines sell for as little as $40 at a Ritchie Bros. auction.
1998 CAT 938G WHEEL LOADER (A67714)
1998 CAT 938G...
2022 Unused Land Pride 1006NT 10ft. Pull Behind Grain Drill Tractor Attachment (A66734)
2022 Unused Land...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
