Help with trailer decision .............
/ Help with trailer decision ............. #1
AuCivil
Alabama
JD4710
Have a JD 4710 with 460FEL and 48BH. Tow rig is a 2500HD GMC. Looking at either a 16 foot Big Tex gooseneck dump or 24 foot gooseneck flatbed. The tractor with the hoe mounted and FEL resting on the gooseneck should fit inside the dump. With the MX6 rotary cutter instead of the hoe it should hang about 4' off the back. According to Alabama public safety office the 4' hanging off is okay as long as it is lit and/or flagged appropriately (guy at the trailer place said it was illegal - not sure who is right.
I've searched the site and read a lot about both types of trailers. Basically on the fence and need to get pushed off one side. Would like a 20 foot gooseneck dump flatbed (or drop sided) but cannot find anything like that in my area.
Any advise is appreciated.
/ Help with trailer decision ............. #2
How much hauling of things that need a dump bed do you do? And what sort of materials? That would be the deciding factors I guess.
Both are nice rigs, the flat bed is better than the dropped or dump bed because it can be easily loaded with a forklift with nothing in the way. And the fenders in a dropped bed pin you down to a maximum width with no leeway, guess that would be the same for the dump bed too.
Can't say about the 4', it is not illegal here, but if 4' or more it needs a flag.
/ Help with trailer decision ............. #3
same question.. do you need the dump bed.
if dumping is a 'MUST' then that pins you.
I know I can't really haul my old ford 850 tractor with a light duty loader and a woods 6500 hoe on a 16' flatbed. puts all the weight in the wrong place for bumperpull. if it were gn.. it might make a significan't difference.
on the other hand.. i really like my flatbed gn. as other sated.. no fenders inthe way. easy to load with a laoder or forklift. but it don't dump.....
weigh your needs.
/ Help with trailer decision ............. #4
I have a Betterbuilt 22' Bumper pull that was built to my specs. The plant is in Double Springs, Al and they are good people to do business with. They will build any type of trailer you want.
I would recommend at least talking to them about a custom trailer.
I only move the TLB from the farm to home and some personal heavy hauling. I have a lot of money in my tractor and I want to move it safely with a good trailer that meets my needs.
http://www.betterbuilttrailers.com
/ Help with trailer decision ............. #5
I think a lot of guy's think that they'll have a dump truck when they get a dump trlr. If your planning on hauling gravel or dirt, a dump trlr/pu tk can realistly only haul a meaningless load of either. They are great for mulch, clean up jobs, or even a small load of logs, but a 5 ton pile of gravel (depending on your job) is a suprisingly small pile! My 2cents says hire a real truck when you need it and go for the deck over.
I also had a Betterbuilt GN deckover, it was a good trlr.
My only "must" would be the ability to transport my tractor, the rest of the uses are just general trailer uses. Hauling larger items, moving duties, temp storage area, hauling limbs and debris, landscape material (mulch), etc...... dump ability is just handy for me since I'm getting older
/ Help with trailer decision ............. #7
10-4 on the dump, gravity is a good thing when applied properly!
/ Help with trailer decision ............. #8
If you have stake pockets on the flatbed, you can put sides on it for hauling some of that stuff. And some things don't dump as well as I think they ought to either.
I had a load of composted horse manure in my 1-ton dump and it just wasn't moving. I ended up pulling it down with the FEL bucket as much as I could. It was pretty damp/wet, I think that's why it was clinging.
Things like stone pour off from the top and back of the load, and other things don't move unless the whole load slides. So, there is some physics/material science involved.
/ Help with trailer decision ............. #9
I found the perfect trailer for me, 4' pop-up dove tail, 5' dovetails tend to drag a lot.
For hauling square hay bales, ramps make a back stop.
For round bales, leave the deck down and ramps hold the last one or two in place.
For equipment, ramps slide in to match tread width, and support the rear when driving up on them.
I ordered it with the receiver hitch and wiring to pull another trailer behind it.
/ Help with trailer decision ............. #11
I use a bumper pull Big Tex 12PI for my !10tlb and 4520 with a 20ft floor and slide in ramps. This has worked very well for me for 8 yrs now. I have looked at other trailers and would consider a tilt bed trailer with open deck too. I prefer the bumper pull trailer over the gn because it is easier to handle.
I agree with others about the dump trailer usage, I have a PJ 14k dump trailer bumper pull and would not consider it a replacement for a dump truck. I pull this with a Ford F550 mostly with debris or mulch, good trailer but not as usefull as it might seem.
I would say the 22' long bumper pull tilt trailer 14k that Big Tex currently offers would be a good choice for moving your equipment.
/ Help with trailer decision ............. #12
Id go with just the gooseneck and have some removable sides made for the brush and stuff. Not to mention you can usually find some good deals on them on Craigslist with a little looking. It doesnt say what city in Alabama you are from, but I know most all rental companies around the Bham area here have 5 ton dump trailers for rent for under $150 if you needed to haul some stone or dirt.
/ Help with trailer decision ............. #13
DITTO THAT. WHY BUY A SPECIFIC TRAILER BUILD ( DUMPER ).. FOR A 1 OR LOW TIME USE.. WHEN YOU COULD SIMLY RENT THE 1-TIME JOB OUT..E TC.
( darn caps... )
( darn caps... )
I am about an hour north of B'ham and have tried the rental route. Cannot find any local reliable rentals. The brakes were hooked up wrong on my last rented trailer (16' bumper pull). My tractor pushed me down a very steep grade for a "very curvy" mile before I could get it stopped. When it got a little darker and the truck light automatically came on, the trailer brakes locked up. They apparently had been wired to the lights.
/ Help with trailer decision ............. #15
I cant recall the company name but the Big tex dealer at the pelham exit just 15 minutes south of Bham had a gooseneck dump that looked to be 20' + sitting on the lot today.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
Gehl Mix-All 95 Grinder Mixer (A66408)
Gehl Mix-All 95...
