PTO Power?
/ PTO Power? #1
philurbs
Ohio
John Deere 2320
Hi All, I am thinking of getting a wood chipper for use with my J.D. 2320. The 2320 has an 18 hp pto and the chipper requires a 19 hp pto. How much of an issue is 1 hp? Any experience in this area? Thanks in advance
/ PTO Power? #2
You will be SLIGHTLY limited on what size wood will fit through it or how fast you can go. In day to day use, you probbaly wont notice a difference.
Aaron Z
/ PTO Power? #3
What wood chipper? They usually have a range of hp. Typically it will work, you just may need to feed slower or less.
/ PTO Power?
Thanks, Wood Maxx WC 8N entry chipper 8" seems like the best value for the money.
/ PTO Power? #5
That will be very big for that tractor. I run a wallenstein bx42 chipper on a kubota b2920 (29 hp). I can stall it with a big log. When the hp is low you want the biggest heaviest cutting wheel possible because the momentum will help. The wallenstein has a very heavy cutting wheel. I'm not familiar with the woodmax so cannot offer any assistance there.
Also make sure it will work weight wise with your 3pt lift capacity.
/ PTO Power?
Thanks for the advice. It has a 185 lb flywheel and is within 400 lbs of 3 pt limit, point taken on perhaps outsized for 2320. Does the Wallenstein come in a smaller model? Maybe a 5" to 7" capacity?
/ PTO Power? #7
there is a 4, 6 and 3" I believe. For your tractor you'd want the 3 or 4" model. They do have a wide chute though, so my 4" is a 4 x 10" chute, so there's no trimming and it fits a surprising amount of stuff. Keep in mind with green hard wood you're not going to get much beyond 3 or 4" of capacity with your PTO HP no matter how big the chipper is. Here is a link with some stats on the different models. I looked at a 6" for my tractor and decided against it because i'd be buying extra capacity that I couldn't use. the 4" is just about right. Wallenstein BX42 Woodchipper | PTO Wood Chipper
/ PTO Power?
I will check out the Wallenstein line. Thanks for the advice on wasted size. 4" is firewood anyway ;o)..............philurbs
/ PTO Power? #9
I did a minute of research on the woodmaxx, looks like its a chinese chipper? I considered some of these, but ultimately didn't want the breakdowns or danger. A good chipper will last virtually forever and isn't something you want to break or have safety problems with. The wallenstein wasn't cheap, but bought used was a great investment. Mine gets heavy use and is a couple years old, i haven't even needed to flip the blades yet. I rarely have something that won't fit, as you say anything that big is good for firewood.
/ PTO Power?
Thanks. for the info. I had read somewhere the WoodMaxx was U.S. made. Thanks for the correction, as I agree with your assessment of chippers made offshore. Anyone out there have experience with other chippers they could share?
/ PTO Power? #11
The Wallenstein comes from our friends up north in Canada. I have the BXM32 chippershredder running on my JD2305. We have same PTO HP. For me, anything bigger than 3" is firewood. The 2305 has no problem with the BXM32.
Frank
/ PTO Power? #12
There are a whole bunch of chinese ones that claim to be made in the USA, not sure how they get away with it, but if you search some reviews you find it quickly. The things you'll want to look at are self feeding or not (wallenstein blades pull stuff in so it self feeds w/o the hydro feed), discharge chute and chipper opening (bigger is better so you don't have to trim forks). Some brands I looked at when I was shopping:
Bearcat, Woods, and salsco. DR also makes one. I personally would also look for a 'direct drive' one VS belt driven, its one less thing to break.
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
