Need a measurement from a tractor with Skid Steer Quick Attach on it's loader
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I am going to build an adapter for my loader for skid steer quick attach. I ordered the Quick Tach Conversion Assembly. The measurement I need is; with no bucket/implement on your loader, the loader lowered to the ground, the SSQA mount plate vertical. Distance from the ground to the top edge of the SSQA mount. I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
Prefer measurement from a full size tractor since that's what this will be used on.
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #2
Mine, while not a Deere but is SSQA, measured 18.5".
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #3
.......I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
The height should be low enough to swap attachments on level ground, and the bottom of a level bucket can go a couple inches below ground level.
Doesn't matter what the machine is, these are all the way down.
Weld on excavator thumb EK1212 (A56438)
Weld on excavator...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2019 Ford F-350 (A55973)
2019 Ford F-350...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
