Need a measurement from a tractor with Skid Steer Quick Attach on it's loader
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I am going to build an adapter for my loader for skid steer quick attach. I ordered the Quick Tach Conversion Assembly. The measurement I need is; with no bucket/implement on your loader, the loader lowered to the ground, the SSQA mount plate vertical. Distance from the ground to the top edge of the SSQA mount. I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
Prefer measurement from a full size tractor since that's what this will be used on.
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #2
Mine, while not a Deere but is SSQA, measured 18.5".
   / Need a measurement from a tractor with Skid Steer Quick Attach on it's loader #3
.......I need to know what height to build mine to when I attach loader mount to the Conversion Assembly. Thanks in advance.
The height should be low enough to swap attachments on level ground, and the bottom of a level bucket can go a couple inches below ground level.
Doesn't matter what the machine is, these are all the way down.
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
