Observations from North Carolina
/ Observations from North Carolina #21
Yep, it has a cab air filter and heat and A/C.
The view out the windshield while brush hogging
View attachment 314305 View attachment 314306 View attachment 314307 View attachment 314308
In another thread, we've been talking about about cutting hay with a rotary mower equiped with a removable side panel. One of the disadvantages of doing this with a tractor is that the tires push down crops with fragile stems. The skid steer mower, with only a pivot wheel in front, should do a much better job of this.
/ Observations from North Carolina #22
Tractors are cheaper than skid steers (especially tracked units) purchase and maintenance wise. We have a small rural county and they use tractors for mowing, grading roads (gravel roads) and some loading and leveling. Cost is the big factor, a small rural county cannot afford many pieces of expensive equipment. They do have dozers, graders, end loaders, dump trucks and other equipment but the tractor uses less fuel and still gets the job done and parts are cheaper. So when they can use a tractor they do.
About the only difference between here and Appalachia is the terrain. We have rednecks here also (me included) but we are happy and would get along fine with the "good ole boys" from south of the Mason Dixon line. In fact if you look at a map, Southern Illinois is further south than most of Kentucky. When you cross the state line into Kentucky we even sound alike.
/ Observations from North Carolina #23
Somehow, I think that would take a little getting used to. (The view, and direction of work, not the A/C in the cab!)
/ Observations from North Carolina #24
Once when I worked with a lady from somewhere up north. I commented that she sounded like one of us, she said she was from a misplaced southern state. It might have been Illinois, wish I could remember.
One other thing I forgot to mention were the cemeteries. Almost all hat I passed that I could see equipment at was a 30 or so hp tractor with a backhoe to dig the graves. I actually went by while one was being dug. It was a JD3320 with a 375 hoe. I have never seen that in CT. A mini or a 410 or something usually does them from what I have noticed. Maybe it is just a cost thing?
/ Observations from North Carolina #26
Perhaps they had a 410 and went with something smaller when they found the replacement cost...
Aaron Z
/ Observations from North Carolina #27
BuzzardA91
Here in Ct. The cost is passed on to the taxpayer so they get the biggest more expensive tractor.
Sent from my iPad using TractorByNet
/ Observations from North Carolina #28
Could be trying to dig a grave in frozen ground with a CUT would be a challenge? Something they don't need to worry about further south.
In the old days, bodies were left in a chapel/crypt until the ground thawed. The service berry shrub, gets that common name from the idea that when it bloomed, it was time to dig the graves of the dead stored during winter.
Dave- never thought of the frost, makes sense.
Dabsgt- you know it, only the best. We are paying for it, no doubt.
/ Observations from North Carolina #30
It would be a real ha ha to be digging a grave with a CUT and hit a New England worthy boulder at about 4' down. :laughing: You aren't going to just move over to a better spot, or dig a trench across the cemetery to wrangle the thing out with a small machine.
/ Observations from North Carolina #31
Dave, if you can believe it there is a small cemetery in my town that when there is the occasional grave to be opened it is still by hand. When frost or frozen they place a large heated pad over the area which is run by generator over night to defrost. If I didn't see it I would not have believed it.
/ Observations from North Carolina #32
I wouldn't have guessed anybody hand dug graves these days. I suppose in an old cemetery that is pretty full, and laid out back in the Civil War days or earlier, that may be the only way to do it without destroying something.
/ Observations from North Carolina #33
One thing to note is that Wilmington is very near the coast and in the southeastern corner of NC. Digging rarely hits rock. The soil is sandy and loamy dependent on where you are.
As far as NC Rednecks, I are one!
/ Observations from North Carolina #34
Wilmington is probably below the fall line in an area that used to be beneath the ocean. My father grew up below the fall line. When he was a kid, he had to break up plow points to have something to shoot in his sling shot.
John Deere 1025R (A62177)
John Deere 1025R...
2017 Kenworth T680 (A64127)
2017 Kenworth T680...
Bad Boy Rogue (A64127)
KBH Tender (A63688)
KBH Tender (A63688)
2007 Ford F750 Dump (A62613)
2007 Ford F750...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
