Omni Transformer vs Heavy Hitch
/ Omni Transformer vs Heavy Hitch #1
PsRumors
Gold Member
Cartersville (NW) Georgia
Kubota L45
I am going to buy a weight bracket hitch combo to use as ballast for my FEL but am trying to decide on which hitch. Both seem to have advantages and disadvantage. I know I could go with a box for much less money but I like the flexibility of the suitcase weights and a few of the attachments each hitch offers.
Omni Transformer - $210 base price plus shipping
TRANSFORMER Platform with Integrated Weight Rack - OMNI Mfg LLC
Likes - integrated bottom horizontal draw, comes with top vertical receiver, bolt on accessories (which is also a dislike)
Dislikes - bolt on receiver hitch (which is also a like), no option for 70lb weights
Heavy Hitch -$219 base price plus shipping
https://heavyhitch.com/store/category-1-hitch/category-1-hitch-and-bracket-for-suitcase-weights/
Likes - is a sponsor here, square tubing instead of angle iron, built in reciever hitch, 70lb weight option ($30)
Dislikes - no horizontal draw bar, extra cost to use 70lb weights, extra cost to have verticle reciever ($80 but does make it a super hitch with heavier metal)
To get a heavy hitch like I want would be $299 plus another $30 if I decided I want the option to use 70lb weights. The omni transformer is $240 once I buy a bolt on reciever.
Any thoughts or concerns on either hitch?
I want to make a purchase today. Thanks!
/ Omni Transformer vs Heavy Hitch #2
Did you look at the Omni Combo Hitch, it has the receiver welded on.
Combo Hitches - OMNI Mfg LLC
/ Omni Transformer vs Heavy Hitch #4
I saw that but like the integrated weight bracket of the transformer.
I have the Transformer (without the integrated weight bracket), and like it. The bolted on Receiver hitch is plenty strong enough for my Toolcat 3 point.
/ Omni Transformer vs Heavy Hitch #5
Well which one did you order?
/ Omni Transformer vs Heavy Hitch #6
Bumping this thread as I am interested in what PsRumors ended up going with and what the experience has been. Also interested in any other input others may have. I am considering the same purchase. Thanks!
/ Omni Transformer vs Heavy Hitch #7
I ordered a a black Omni Heavy Duty drawbar hitch assembly that has the grab hook welded on it. I could not be happier with it. I have it mounted on an OLD USA made heavy drawbar that isn't bent up. The holes match perfectly, I sandwiched a gasket from truck innner tube between the two pieces. The hitch is USA made, painted with finished fabrication. welds are nice, corners and edges rounded. It came with two bolts,nuts, washers, a top hitch pin and a receiver pin. A first class attachment that I am glad to have. They get my vote. It is **** for stout.
/ Omni Transformer vs Heavy Hitch #8
With all respect due:
Pictures or it never got bought...
Preferably action shots with any customization you added.
Thomas
/ Omni Transformer vs Heavy Hitch #9
ya want pictures eh, well by golly here ya go
/ Omni Transformer vs Heavy Hitch #11
It makes a nice fit when you are bolting it together. Cast bar has a bit rougher surface than rolled steel. That's the way I like it uh huh.
/ Omni Transformer vs Heavy Hitch #12
I just bought an Omni Transformer with weight bar and the basket accessory. Both are built like tanks. Full length welds everywhere. And they are all nice and neat. Come with full compliment of hardware too. I haven't had a chance to put it on my tractor yet. But, when I do I will post photos. I'm expecting it will stay on my X739 almost all the time.
/ Omni Transformer vs Heavy Hitch #13
Congratulations!
Looking forward to action shots.
Thomas
/ Omni Transformer vs Heavy Hitch #14
Well it took all day, but I finally got the 3PH hitch installed on my new X739. What a PITA! Then I installed my Omni hitch :)
/ Omni Transformer vs Heavy Hitch #15
Don't know why they are upside down. Edited and try again:
/ Omni Transformer vs Heavy Hitch #16
I have an Omni combo unit for my BX, it's a super nice, well fabricated piece for reasonable money.
/ Omni Transformer vs Heavy Hitch #19
I understand that the rubber is to help match up the two surfaces better, but under heavy loading it may lead to loss of preload in the stack. This is not good for a bolted joint and should be avoided. Can you take a grinder to the uneven surface and flatten it out then shoot it with some paint and bolt it back without the rubber? That's a nice looking hitch adapter and I'd hate to see it come loose on you while you're working it hard. ... and do it the very best you can.
/ Omni Transformer vs Heavy Hitch #20
Rock @ OMNI here. For all of you who are wondering, the bolt on receiver is included with the the Transformer as well as 3/4" Grade 8 bolts to attach it. Also please consider that our Transformer is built with 3" x 3" x 1/2" angle compared to the 3/16" tube on the HeavyHitch. Price of the Transformer is $230 not $240.
Also I really want to thank all of OMNI's customers that have taken their time to post comments about and pictures of your hitches. We cannot BUY advertising that valuable!
