using chain for a top link ?
/ using chain for a top link ? #1
Rmart30
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
I was reading back thru the archives and in one post someone mentioned removing the stiff top link and using a chain instead when using a box blade or disk to allow it to follow the land contour better ..
How many of you use a chain top link and for which implements?
/ using chain for a top link ? #2
I have done it, also works with finish mowers, it allows all 4 wheels to ride on the ground
/ using chain for a top link ? #3
I use a chain with my brush hog. Works great!
/ using chain for a top link ? #4
Mowers are OK. Their rear is heavy enough to hold them on the ground.
3PH discs tend to pitch forward on flat ground without a solid top link to hold them level. A box blade, blade, landscape rake, plow, or other land engaging equipment would have the same problem. That is why "draft control" was developed. A chain would be so much simpler but a solid top link was invented for a good reason.
/ using chain for a top link ? #5
I agree with GW. Don't think you'd like a chain on a land engagement attachment. I used to have a picture of a JD CUT with 3pt brush cutter and chain top link but I can't find it. He backed it up a 45 degree bank with tractor on flat ground. Very few flexible hitch assemblies on cutters will let them float that far. If you try a chain with PTO driven equipment, try it out with the PTO OFF first to make sure your chain can't get tangled up in the PTO shaft. That would not be pretty.
/ using chain for a top link ? #6
I used to use a chain with my LandPlane Grading Scraper so it would follow the contour. But I ONLY USED IT AFTER I was sure there were no places in the road that would catch a blade and cause it to roll up violently. I didn't know it at the time but it would have been safer if I put the chain thru a length of pipe a little shorter than the chain. The pipe would act as a safty stop and prevent the grader from coming all the way up and hitting the tractor. I have a hydraulic top link now so I don't use the chain.
I can't see how a chain on a box blade would work. Wouldn't it just roll forward and ride on the front corners of the box with no cutting force on the blade ?? At least a grader is back heavy and made to run flat on the surface. For that the chain worked pretty well allowing it to follow the contour. But again if I hit something it would jump up and roll forward very violently. It never hit the tractor but it was scary.
Edit: I wasn't thinking on the BB comment. I guess you could hold the front corners up with the 3ph control and just drag it along on the blade. But if the front blade caught it would roll forward in a hurry as the other have said.
/ using chain for a top link ? #7
I use a Hydraulink top link for 'hogging and box blading. If you search Hydraulink there is a ton of info here on T-B-N.
Hydraulink is at its best with these two implements.
I received a Ford 101 2-12 Turning Plow from Sweet Tractors today. I am looking forward to adjusting it tomorrow and testing the Hydralink with the plow.
/ using chain for a top link ? #8
Just another reason why one wants to have the float function available for their hydraulic top link. My understanding is that using a chain instead of a rigid link of some sort can be VERY dangerous. Obviously many people have done this without incident, but I believe it to be a bad idea.
Just my :2cents:
/ using chain for a top link ? #9
Just my :2cents:
I'll second that. There is no way to keep the implement from coming over on the operator.
/ using chain for a top link ? #10
I have a pallet fork type attachment with a chain attachment for the top link. Probably not safe for a tall load which could tip back on the operator, but fine for loads only a few feet tall.
/ using chain for a top link ? #11
Hydraulic top link would be the better option. My 3rd service has a float option and the box blade does not work as well in float.
/ using chain for a top link ? #12
I can see how that would work fine with the weight extending the chain and putting tension on it. A problem might arise if, when traveling forward, the heel of the forks caught on the ground, on a curb, or something like that. The fork tips would whip upward and dump the load on the operator. Just don't be carrying a 55 gallon drum of sulfuric acid. :eek:
/ using chain for a top link ? #13
There may be certain things where using a chain for a top link may work, grading is not one of them. ;)
/ using chain for a top link ? #14
I haven't had a chance to try it yet, but that's how I'm thinking I'll run my hydraulic top link when pulling my 3pt mounted brush cutter. That will give even more flexibility over uneven ground than is built into the hitch of the cutter. Good point.
/ using chain for a top link ? #15
I once owned a rotary cutter that had a top link made 1/2" thick by 1 1/2" bar stock with a 8" piece of chain welded on the cutter end. I had it many years and that set up worked very well.
/ using chain for a top link ? #16
The chain is attached at two points, with a few inches of slack. You'd need more chain or better yet a solid top link to connect it. I think the intent is to provide limited float to aid in picking things up. I bought this piece at auction. It probably weighs more than a quarter of my TPH capacity. I imagined using it to move firewood on a pallet, but never have. Not very useful, but still part of my attachment collection. :)
/ using chain for a top link ? #17
Steve, I like that. Allows your forks to follow the terrain if trying to get under an object without the points digging into the ground!!!
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Rolling Shop Stool (A66408)
Rolling Shop Stool...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
