Need chipping advice
/ Need chipping advice #1
coreshot
Gold Member
Utah
Kubota BX24
Back story, last summer my 6.23 acres of cabin property went up in a 40k acre wildfire. I now have thousands of charred dead trees that need to come down. My plan is to methodically drop the trees and harvest the bigger stuff for firewood, and chip the smaller stuff. What is going to be a good unit for the size and scope of this job? I figure I'll chip anything under 3 inches in diameter, but I want a unit that will run efficiently and not work too hard. Would a PTO type setup be better than a self powered machine? I have a BX24, so 17-18 HP at the PTO. Trees are pinion and juniper. Thanks
/ Need chipping advice #2
I've always dreamed of having a proper PTO chipper myself, but the price is holding me back until it becomes more of a necessity. Even with just 17 or 18 HP at your PTO, you should be able to hog through 3" limbs no problem. A big big branch could slow your engine speed down some, but I wouldn't expect any issues, from what I've read. I would look at a Wallenstien bx32 or bx42, they seem to really be the best value (not cheap though!).
BX42r/BX62r Wood Chippers - Wallenstein
/ Need chipping advice #3
First of all, really sorry to hear that you were subject to the damage of those wildfires.
I have about 50 acres of woods, so you can imagine how often I'm cleaning up the fallen / dead stuff. With the HP range for your PTO, and the smaller size of your property, I would suggest just renting a bigger tow-behind chipper from a local rental company.
I just rented one this past weekend for $140 from Sat. morning until Monday morning. I chipped about 8-10 yards in that time! (See pics below). To get into a QUALITY 3-point chipper for purchase, you're going to spend 10x that at the very least. My only regret is that I should have rented a bigger chipper. The one I rented could handle up to 4" limbs, but since it was gas-powered, the chipping went a little slower than I was hoping.
My other option was a monster diesel chipper from United Rentals for $400 for the weekend that could chip up to a 12" limb (!!!). Looking back, I probably would rent the bigger one next time.
Good luck with your project!
/ Need chipping advice #4
I would keep my eye out for a used PTO chipper as it sounds like you might be at this for a while. I tend to do some clearing ~twice a year so bought a used Bearcat chipper that I found on Kijiji.
I thought about renting a big one, but my job isn't going to allow me to do it all in one weekend. I guess I could cut all the wood and pile the branches to be chipped and do it all at once. But then, burning it would be just as easy at that point. Prior to the fire, I planned on purchasing an 11 hp Bearcat to use as I progressively trimmed the trees on my property, now I really just need a one time deal. Maybe a rental is the way to go...
/ Need chipping advice #6
Well, I just stopped myself and thought of it like this...
Ideally, I want to buy a Wallenstein BX62 for my 50hp tractor. That's $3500 new, and they are dang hard to find used. It sure would be convenient to have it on my property, with trees falling all the time from storms, and constant sapling clean up. However, I could rent that bigger chipper ($400) 8 times before I got to $3500. And I could rent that smaller chipper ($140) 25 times before I paid as much as the BX62. And I get to "use and abuse" those units and just tow them back and drop them off. No worries about breaking anything to fix, or sharpening anything, etc.
That's what helped me to make my decision. YMMV, however.
But I would think that with 6 acres, you could do a couple weekend rentals and get it all knocked out in a month or so. Then, you would have a ton of wood chips to spread and compost the soil, too! :thumbsup:
I like chipping vs. burning most of the time because you are left with a very useful by product, and are not exposed to the risk of spreading a fire. And you don't have to wait for mother nature to rain so it's safe to burn, ha!
Anyway, this is just how I have calculated what works for me. I really want to buy a BX62 someday, and I will, but if you can pile up the brush and just feed it through a chipper for 4-6hours, that works really well.
Good points....I think that's the route I'll probably go. Not much worry about fire spreading though, theres nothing left to burn. :laughing:
/ Need chipping advice #8
With the size tractor you have...a Wallenstein Bx32 is the best you can handle...the chipper can take 3"...but your tractor will be working at it's max.They're very good well built machine.I have 42 on a 50 hp MF...very happy with it.
/ Need chipping advice #10
I run a Wallenstein bx42 chipper on my JD 2720 with 23.5 pto hp and it's a great match. You could easily run their bx32 with no problem. I have around 2 1/2 acres packed with 80-foot pine, cherry and maple trees and every year there are more branches to clean up. I used to rent a 25 hp commercial grade chipper each spring but at $200/day it was adding up and I didn't like having to rush to get it back to the store by the end of the day. Now I can take it out when I need it and work at my own pace. It'll do a 4-inch branch easily but anything over 3 inches is firewood to me so I never work it to its max and I don't have to rev the tractor way up to get the job done. It also has a large rectangular opening to accept odd shaped branches or crotched branches. It feeds great and is worth every penny, but if you don't intend to use it regularly then maybe rental is your best option. I just happen to like having it available when I need it. Good luck.
/ Need chipping advice #11
We have 300 acres and planning on getting a bx42 to go on my Kubota l45 can't wait to get it and try it out!:)
/ Need chipping advice #12
The BX42 is a great chipper but it's not a shredder. I think the few negative comments I've seen about it come from the fact that it isn't designed to eat small branches with other small branches coming off of them. They just get hung up in the chute and you end up having to push them into the chipping wheel. I could have gone with the BXM42 to get the shredding hopper in addition to the chipping chute but it was just too big for my taste and not suited for my tractor. There are times when I have to prepare the pile by lopping off the offshoot branches to create more straight branches that feed better but it's a small trade off for the smaller attachment that doesn't take up much room and is easy to maneuver. I just got done using it for a few hours and it has been well worth the investment. I'll post some photos soon.
/ Need chipping advice #13
Hello I have a Wallenstien BX42 on my38hp Pasquali tractor and it performs great. I use it for getting rid of brush/limbs after wood harvesting and it doesnt have a problem with limbs with branches on it. I used to have a DR chipper that had a 3 inch limit but the issue with it was the ability to get llimbs with branches on it down the shute. The BX42 will take almost any oddly shaped limb with branchs and self feed it in.
Occasionlly it clogs on pine branches so I just need to mix that in with some hard wood. Also when the blades get dull it will not self feed as well with small branches and is a good indication its time to reverse or sharpen the blades.
/ Need chipping advice #14
However, I could rent that bigger chipper ($400) 8 times before I got to $3500. And I could rent that smaller chipper ($140) 25 times before I paid as much as the BX62.well.
......also calculate the resale value of those dang hard to find used chippers when your done with the project and subtract that out of your expense. Say you can resell it for $2700, then how does renting look?
/ Need chipping advice #15
Like I said, it's a chipper and not a shredder. It does perform very well and will eat anything as long as the branches can reach the chipping wheel, and if the branches have a bunch of smaller branches sticking out from the main branch, they'll never even get to the chipping wheel. A series of small branches will also clog the exit chute, as you and I both noticed. My point was that the Wallenstein chipper/shredder would be ideal to cover all the bases but it's too big for my tractor. I went with the chipper and just prep the branches beforehand or make a pile of smaller branches and borrow my father's Bearcat chipper/shredder when the pile gets big enough. He lives just 5 minutes away and is happy to loan it to me because he's a good dude.
/ Need chipping advice #16
Hi Gus I havent had any problem of it not pulling in limbs with branches, the only issue is with pine occasionally it will clog but all I do is mix it with some hard wood and go easy and its fine. Its really an issue of of the gap between the stationary blade and the moving blades if the gap is two wide it will allow the smaller branches to go through without geting chopped.
/ Need chipping advice #17
I put a Wallenstien BXM32 on our new Kubota BX25D and although I only put an hour on it up to this point it eats anything around 3" and then some. The chipper is good for a 1" and a bit.
/ Need chipping advice #18
Great set-up. I like the bottom stand with the tool box and the pocket for the trimmers.
/ Need chipping advice #19
So If I understand correctly, you are going to be chipping the charred remains of a fire? Man, that is going to be a messy job.
I have a Wallenstein BX42 on my B3300. No problem feeding since it has a 4" x 10" capacity. Like someone else pointed out, the Wallenstein will have a great resale value if you ever decide to get rid of it.
/ Need chipping advice #20
Thinking outside of the box, with my experience
You might think of leaving scattered dead black fire kill trees. Over a period of time they will enhance wildlife habitat.
Cutting and piling to chip especially in firekill is dirty and nasty and very bad for your lungs. Think of the charcoal carcnigens.
You SHOULD wear a respirator. Generally the easiest way to chip multiple trees for a small set up is to fell and chip. Cut one, or two and chip. It is easier to sort out and not so overwhelming. If you go in there and fell them all over the place you will have a mess to contend with. Directionally fall them so you can minimize your picking up and sorting.
I have extensive logging experience as well as residential tree chipping. just my two cents worth. Work and play safe
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2018 Monroe Towmaster TC-16 10 Ton T/A Tag Trailer (A64556)
2018 Monroe...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
500 GALLON FUEL TANK (A64278)
500 GALLON FUEL...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
