quick hitch top link bushings
/ quick hitch top link bushings #1
coldfingers
Warren, Mn.
2013 Kubota RTVX-1120D, kubota ZG 227, kubota LX 2610
I thought I saw a thread on this somewhere, what size bushing does a guy need to take up the play in your implement top link pin when you have a quick hitch? Its a catagory 1 quick hitch. Where is a good place to get them at? Thanks.
I got those Murph, it is the top link pin that I need a bushing for.
/ quick hitch top link bushings #4
I just bought a speeco, the implement comes with a pin but it seems sloppy in the quick hitch so I figured you must be able to put a bushing over the pin so it fits snugger in the quick hitch? maybe?
/ quick hitch top link bushings #7
On my land pride only link bushings used but you can get bushings from NT for what you want to do. same cat1 to cat3
Thanks Murph!!
/ quick hitch top link bushings #10
I just installed a Rankin Quick Hitch on my L4600 Kubota. I got a set of bushings for that as well as the two implements I bought at the same time from the dealer I bought the set up from. The Grader and the 72in Mower...both Land Pride. I did discover the Rankin Quick Hitch I got had inferior bolts holding the top hook onto the rack. They both sheared off in the first use. I went to IH Case cause they were closer than the Kubota dealer and got some grade 8 bolts and replaced these so be aware.
Best Mike
/ quick hitch top link bushings #11
The only place I found the right size bushings was from the Land Pride dealer. Their QH comes with a set of them and they have several different lengths available. If they are too long I cut them to fit the space. They have for both top and bottom hooks.
Ron
7888SFL (A61567)
7888SFL (A61567)
John Deere 7000 Planter (A63109)
John Deere 7000...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
UNUSED 2026 INDUSTRIAS AMERICA 7014R 7'X14' DUMP T (A62130)
UNUSED 2026...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
