quick hitch top link bushings
/ quick hitch top link bushings #1
coldfingers
Warren, Mn.
2013 Kubota RTVX-1120D, kubota ZG 227, kubota LX 2610
I thought I saw a thread on this somewhere, what size bushing does a guy need to take up the play in your implement top link pin when you have a quick hitch? Its a catagory 1 quick hitch. Where is a good place to get them at? Thanks.
I got those Murph, it is the top link pin that I need a bushing for.
/ quick hitch top link bushings #4
I just bought a speeco, the implement comes with a pin but it seems sloppy in the quick hitch so I figured you must be able to put a bushing over the pin so it fits snugger in the quick hitch? maybe?
/ quick hitch top link bushings #7
On my land pride only link bushings used but you can get bushings from NT for what you want to do. same cat1 to cat3
Thanks Murph!!
/ quick hitch top link bushings #10
I just installed a Rankin Quick Hitch on my L4600 Kubota. I got a set of bushings for that as well as the two implements I bought at the same time from the dealer I bought the set up from. The Grader and the 72in Mower...both Land Pride. I did discover the Rankin Quick Hitch I got had inferior bolts holding the top hook onto the rack. They both sheared off in the first use. I went to IH Case cause they were closer than the Kubota dealer and got some grade 8 bolts and replaced these so be aware.
Best Mike
/ quick hitch top link bushings #11
The only place I found the right size bushings was from the Land Pride dealer. Their QH comes with a set of them and they have several different lengths available. If they are too long I cut them to fit the space. They have for both top and bottom hooks.
Ron
