Backhoe BACKHOES LETS SEE THEM
/ BACKHOES LETS SEE THEM #321
The pump is a Prince 295431. The Four point attachment (photo 8) on the BH fit in,the four rusty hook type areas (two hi, two low..each side of pto, photo 2 &3) and have two pin that actually attach it (photo 5 & 8). The pump is steadied with the bracket bolted to it and slid over small plate of steel attached to the trailer hitch (next to pump photo 5). The bracket on the pump is beat up, before I put my larger tires on, it hung about 4" off the ground and got caught on everything. I need to replace my pto seal. If I can back up to the BH right, it takes less than 5 minutes to put it on-I like the setup alot.:D
/ BACKHOES LETS SEE THEM #322
Looks like I am the only one with an old cub cadet backhoe and manual thumb EX3200
That is a nice TLB and its even nicer in my mind since it is a Yanmar. It looks like the BH is probably made by the same manufacturer that makes them for John Deere. I like the thumb set up. It looks like you could make that into a hydraulic run thumb without too much difficulty. That is what I want to do with my 990 and 8B BH.
/ BACKHOES LETS SEE THEM #323
I am not familiar with Mahindra tractors or their BH. It looks like they use the Bradco BH and that is pretty nice having the pump and reservoir right there hooked to the PTO. I am guessing that really gives some fast flow and enables the BH to work pretty well. It looks like the hook up for the sub frame is pretty solid as well. I also like the hookup they have for the thumb as well. Nice looking TLB.
/ BACKHOES LETS SEE THEM #324
I thought about putting hydraulic on it, But I need the exercise of getting off and positioning the thumb any way.
/ BACKHOES LETS SEE THEM #325
Making a roadway into the woods. The rock was too heavy to move, so buried it instead.
/ BACKHOES LETS SEE THEM #326
I hear you. the problem is when you get tired and don't want to get off the seat to do it one more time!
/ BACKHOES LETS SEE THEM #327
/ BACKHOES LETS SEE THEM #328
Here's one of mine. Yanmar B27-2B (U.S. model) Probably the handiest, & most economical piece of equipment I have on my tree farm. Also, it's a kick in the pants to play with. The IH backhoe is semi-retired now and stays in the barn most of the time......Dan.
/ BACKHOES LETS SEE THEM #329
home built .... it ain't pretty but it works well.......
/ BACKHOES LETS SEE THEM #331
farmall 55a case said:
That is nifty little backhoe you built!
It would be cool to see a walk around video of that and some action footage. You should be proud of your project. Looks great!
/ BACKHOES LETS SEE THEM #332
I agree nice job. Wish I had that talent.
Sent from my iPad using TractorByNet
/ BACKHOES LETS SEE THEM #334
yes it is for the FEL ... it got too cold to put the cylinders / spool / and hoses on last year before it snowed. the FEL bucket is to the left of the tractor ...
its only a 10 HP with a manual transmission and a PTO off the front.... the backhoe looked too large when fabbing up, but just about right when it got installed.
only real complaint is that I built the backhoe bucket too small ... 12" wide 12" deep by 20" front to back ... OK for trenching for a pipe but should be more like 20 " wide 10" deep by 20" for any real work....
/ BACKHOES LETS SEE THEM #335
another project for spring ...... buckets, can't have enough of them .... levelers, rippers ....:laughing:
I thank you all for the compliments... but there are much better home builds around .... and lots of nice machines / toys on the forum.
Finally fixed my backhoe so I can get back to work just two more trees to go!
/ BACKHOES LETS SEE THEM #340
BigMoB I think that Long 1200 as more reach than most any backhoe attachment. When moving to keep digging do you just do it with the hoe?
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
Generator (A61572)
Generator (A61572)
2003 Freightliner FL60 Ambulance (A61573)
2003 Freightliner...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
