B7610 tractor
/ B7610 tractor #1
hpriddle
MA
Kubota B 7610
My B7610 tractor is slow starting and runs for a few minutes and stops. I then must wait a while before starting again. I have changed the fuel filter, air filter
use fresh diesel fuel. Any help would be appreciated. The Kubota dealer is about an hour away and very expensive.
Richard
Ashby, Ma.
/ B7610 tractor #2
is it getting enough fuel that could be the problem try bleeding the fuel system you might have air in the line
/ B7610 tractor #3
Richard
Ashby, Ma.
Did this just happen recently in cold weather?
Have you tried Power Service Diesel 911?
/ B7610 tractor #4
I agree that it sounds like a fuel supply issue. Adding to Newbury's suggestion, I would remove the fuel filter bowl and add some of the 911 right into that and put it back on. It will get through the line to the injectors directly (concentrated) and work quicker if the problem is in that section.
Do you have a block heater or other way of warming it up? Even if it isn't super cold out- it might help in this case.
2019 WACKER NEUSON EZ36 MINI EXCAVATOR (A62129)
2019 WACKER NEUSON...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
CLAY TRAILER 36 GOOSNECK TRAILER (A62130)
CLAY TRAILER 36...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
