B7610 tractor
/ B7610 tractor #1
hpriddle
MA
Kubota B 7610
My B7610 tractor is slow starting and runs for a few minutes and stops. I then must wait a while before starting again. I have changed the fuel filter, air filter
use fresh diesel fuel. Any help would be appreciated. The Kubota dealer is about an hour away and very expensive.
Richard
Ashby, Ma.
/ B7610 tractor #2
is it getting enough fuel that could be the problem try bleeding the fuel system you might have air in the line
/ B7610 tractor #3
Richard
Ashby, Ma.
Did this just happen recently in cold weather?
Have you tried Power Service Diesel 911?
/ B7610 tractor #4
I agree that it sounds like a fuel supply issue. Adding to Newbury's suggestion, I would remove the fuel filter bowl and add some of the 911 right into that and put it back on. It will get through the line to the injectors directly (concentrated) and work quicker if the problem is in that section.
Do you have a block heater or other way of warming it up? Even if it isn't super cold out- it might help in this case.
2025 New 6 Seater Electric Golf Cart (A65579)
2025 New 6 Seater...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2007 Ford F-150 Pickup Truck (A64556)
2007 Ford F-150...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
