Backhoe John Deere 1026R backhoe
/ John Deere 1026R backhoe #1
ceriderf
Grantham, NH
Deere subcompact
Hi,
I've had my 1026R for about two months now and only had to get towed out of the mud once so far!
Anyway my backhoe slowly falls to the ground over a day or two (if not pinned), is that normal or is there a leak in the hydraulics?
Thanks,
Nick C.
/ John Deere 1026R backhoe #2
Completely normal.
And welcome to TBN!
/ John Deere 1026R backhoe #3
same with my Kubota BX25, don't think it's anything to worry about.
Great thanks for the responses. I'm glad it's normal and not in need of service, I'm having too much fun with it right now!
/ John Deere 1026R backhoe #6
I am having the same problem with a new 1026. It was dropping to the ground in about 30 minutes. I returned mine for repair. Deere is claiming it is normal but I do not agree. Hydraulics are a sealed system and there should be no leakage. Deere is claiming the backhoe is too heavy for the small cylinders on the unit. If it is normal then why can I leave the loader up and why doesn't the bucket open etc.
/ John Deere 1026R backhoe #7
Do you have a lock on your BH?
I thought the dropping was also a problem of a leak. I now pin the backhoe up when not in use, I accidentally drove off a few times with it dragging on the ground forgetting to lift it. I will mention it to the dealer when I bring it in for servicing, probably late spring or summer. Otherwise it works fine and I haven't noticed low fluid levels yet.
/ John Deere 1026R backhoe #9
I can't remember what it is (and I'm not home to look) but JD has leak down rates for the the different parts of the FEL and backhoe. They aren't 30 min either, they are in inches per hour. I would make the dealer find and tell you the proper max leak down rate. Overnight, sure they will often drop (although mine takes about two days to hit the ground without the pins)... But 30 min just isn't right.
If you want to have this info yourself get the service manual from JD. It's really good and well worth the money.
/ John Deere 1026R backhoe #10
I can pin it to keep it up but what a pain. I use the backhoe to loosen the material then turn around and move it with the loader. Jumping down to install and remove the pin is a pain. The back hoe should not drop. If I am driving over rough ground it even drops faster.
/ John Deere 1026R backhoe #11
Sounds to me that it is leaking down too fast, not normal.
FWIW, it is best to leave the fel bucket on the ground when you park to reduce the strain on the seals and either pin the hoe up or rest the bucket on the ground too. My backhoe and loader can leak down but would take over a week to do it and that is with over 1000 hours on it.
/ John Deere 1026R backhoe #12
You should not have to pin it up unless not to be used for awhile.
/ John Deere 1026R backhoe #13
My B 26 leaks down overnight if not pinned and the bucket will leak down a bit over a week or so, same with the stabilizers. Leaking down to have the bucket dragging in 30 minutes, I would say is unacceptable leakage although your dealer might say this is normal, IT isn't normal. This reminds me of the fellow who had a Ford car that used a quart of oil every 500 miles and FORD said that is acceptable oil usage, BS is what I say but what can you do if they say that amount of leak down is OK.
As for pinning the boom, you have to get off the tractor to pin the boom? Mine has a lever that I move from the seat to unpin the boom just like all the industrial hoes have. It also has a boom removable swing pin that I can pin from the seat and has a storage pipe that it slips in when not in use so you don't have to worry about loosing it.
/ John Deere 1026R backhoe #14
My Kubota 2620 with the bh65 bh leaks down over a couple of days. The bucket will open a bit (few inches) over the same time. When I am using the hoe I never pin it to move it and have had no problems. Like others have said, make the dealer show you the specs. Maybe try one in his yard while he watches!
/ John Deere 1026R backhoe #15
Just a suggestion. Every time you go over a bump you are bashing the weight of the backhoe against the cylinder. It's not a shock absorber. That's more shock loading than any normal use of the backhoe and creates an opportunity to cause damage. If it doesn't leak down very much now, keep bouncing around with it unpinned and it will get worse soon enough. It's probably OK to operate the tractor slooowly when the BH is not pinned up, but it will last longer and give you less trouble if you pin it before doing any rough stuff.
/ John Deere 1026R backhoe #16
I agree with this post.^^^^^^^
/ John Deere 1026R backhoe #17
Any way you can weld a handle in the pin so you can place it or release it from the seat? That would make using it more likely. On the old JD 310C we had a pie e of 1/4" rod welded to the pin, loop handle at the top.
Jim
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A62130)
2020 CHEVROLET Z71...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
INOP/NON-RUNNING 2005 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDL85HN88678 (A61165)
INOP/NON-RUNNING...
