Circulating Pump / Heater
/ Circulating Pump / Heater #32
How about a heated shop or garage to park it in:D
/ Circulating Pump / Heater #34
Sorry my reference to the stronger starter was what Tim had said. Can you get one? I don't know. I would ask at your local shop and even try calling Robin. How do they do it on skid steers and all of the other hydraulicly driven equipment that doesn't have a disconnect? In my eyes they just have enough grunt in the starter and enought storage in the battery. But I do know that more CCAs helps to, sometimes a lot. When I change my battery i will deffinatly go up on the CCAs.
/ Circulating Pump / Heater #36
Just make sure the battery fits. Its kind of tight in mine.
I am envious of you all who have an engine compartment arrangement that allows a normal Gp 24.
I have a stupid lawn tractor size battery in mine, and it is barely enough when it is cold. I could see a bit more capacity could go a long way in resolving cold start problems.
/ Circulating Pump / Heater #37
I could be wrong but I was pretty sure I saw High CCAs on batteries of the same size.
/ Circulating Pump / Heater #38
I have seen lawn service battery's at a CCA of 300 in several different places.
A warm battery will help also.
/ Circulating Pump / Heater #40
Lawn tractor batteries with 340CCA are on the parts shelf here. On the topic of cables. Many folk look at the red cable from battery + to the starter.
Every bit as important is the often neglected - chassis return(ground) cable. A beefy cable from battery to a starter mounting bolt will often add significant cranking power.
I was amazed at the starter voltage increase and cranking rpm increase on my JD 1640 with the - cable upgrade
A chassis return through sheet metal and bolted assembles is a source of phantom voltage and therefore power loss.
1005 (A61166)
1005 (A61166)
2017 Bobcat T770 Compact Track Loader (A61307)
2017 Bobcat T770...
YANMAR SV40 EXCAVATOR (A59823)
YANMAR SV40...
2011 Caterpillar CB34 (A60462)
2011 Caterpillar...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
