Loader Bx2360 hydro valve kit question
/ Bx2360 hydro valve kit question #1
hreha
Hi all I'm new on here so I hope I'm doing all of this right. Here goes I bought a bx2360 new last spring and now I'm finally getting around to adding a few things to it. I just got a bx7326 and I'm putting it on as soon as it gets here, I'm looking at adding a loader valve (bx2324) for about 700$ clams my question is can I use a bx2014 ? What is the difference in those two valves and if it would work would there be any limitations . Thank you all in advance for your help in an area that I'm truly a novice, John
/ Bx2360 hydro valve kit question #2
I have no idea cuz I don't have anything that fancy. But welcome aboard! :thumbsup:
/ Bx2360 hydro valve kit question #3
Welcome John! What is a bx7326 and where did you get the other part numbers?
The bx7326 is rear remotes for my bx2360 and the bx2324 and the other are both 4 position loader valves. My dealer said that the bx2324 is the one I need but the bx2014 seems to be the same item, just not sure and this place seems to have a lot of very smart people when it comes to these tractors thanks
/ Bx2360 hydro valve kit question #5
Is your part number a kit with hoses, fittings, adapters, and brackets, or is it a bare valve? If it includes all the goodies, I guess that's a reasonable price. If it's just a valve, you can do a lot more for $700.
/ Bx2360 hydro valve kit question #6
I would guess one of the valves is a spring centering and the other one is a detent valve. That price sounds to me a little high. The price seems more like for 2 sets of remotes. If it's for 2 you might want want one of each. My self I like the spring centering.
The two sets of rear remotes the bx7326 was about 350$ and ive already bought them just waiting for them to arrive so that i can install. and the bx2324 is the front loader 4 position valve it's about 700$ and does come with all of the goodies but the bx2014 is a 4 position loader valve that says its for a la211. The la243 is the loader that is for my bx2360 but just wondering if the la243 would hook up to bx2014 the price on the bx2014 is a very large price drop vs the bx2324 (about 450 cheaper) the bx2014 also comes with all the goodies. Really appreciate all of the help thanks
/ Bx2360 hydro valve kit question #8
The la211 is the older version of loader that went on the BX2200. It may not mount the same because for many years the loader valve was attached to the loader and not the tractor. I would get the one the dealer says fits your machine.
Sent from my iPad using TractorByNet
Thank you very much I figured there were some differences but just had no idea what. It all pretty new to me when it comes to adding stuff to it
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2006 Ford E-250 Cargo Van (A64556)
2006 Ford E-250...
2022 Mercury Verdado 300HP Outboard Boat Motor (A64557)
2022 Mercury...
9008SFL (A64556)
9008SFL (A64556)
Massey Ferguson 285 Tractor w/ Loader (A66285)
Massey Ferguson...
