Grind the bevel off weldable hooks?
/ Grind the bevel off weldable hooks? #21
Carl, if I read your post correctly in comparison to the photos, are you recommending that I lift the hooks up slightly from the surface I'm going to weld them to? If so, what do recommend, 1/16th or so?
You don't have to, it is just a suggestion. It just insures that you get 100 + % penetration. It is a form of open root welding.
Oh I forgot, if you decide to gap the hooks. 1/16" is plenty, or even just use the same wire you will be using to weld the hooks on with. .035"?
Yup, .035 with CO2/Argon mix gas.
/ Grind the bevel off weldable hooks? #23
Just a good rule of thumb. Bevel, and gap everything, hard to go wrong when doing those two things.
But, placing a gap, or doing open root welding takes more time to get use to. ;)
I'll add it to my practice welds and see how I do!
/ Grind the bevel off weldable hooks? #25
The big problem with Mig welding is, anybody can pick one up and make a very pretty weld. I'll bet you anything, you let me set your machine, and stand over your shoulder for 5-minutes, and I'll have you laying down beautiful welds! Does that mean you're ready to build a trailer by yourself that is gonna be going down the hiway? NO WAY! Most people don't understand how important joint prep is to welding! There is way more to welding, than pulling a trigger on a Mig machine! ;)
/ Grind the bevel off weldable hooks? #26
Couldn't agree more. That is why the suggestion of avoiding MIG and going with stick was made earlier.
One just DOESN'T want those hooks snapping off at an inopportune or critical time.
/ Grind the bevel off weldable hooks? #27
I'm DEFINITELY going to buy a couple extra hooks and practice welding them. I don't stick weld, only MIG so my choices are limited, that's why I want to make sure I do it right. I'd rather go through a couple hooks for practice than do a shoody job welding them on the bucket and have them fail.
/ Grind the bevel off weldable hooks? #29
Multi pass !!!!!!!!:thumbsup:
I had the hardest time getting a clean root on those hooks when welding them to a piece of flat stock. The rod was so deep in that I couldn't really see what the puddle was doing.
/ Grind the bevel off weldable hooks? #30
Weld a good first pass then add another on the bottom toe of that weld. Then one on top of the second weld. Use some scrap pieces to practice on. Check the pics on my post. I pulled out some 30" oaks 50' long from those hooks. Those were even welded with my old Herbert welder!!:confused3:
/ Grind the bevel off weldable hooks? #31
Did you see I welded my hooks on with 7018? I'm not afraid of Mig / wire feed, but I've probably run more spools of wire than most here have seen. A Mig welder in the wrong hands does give me concern, that is why I try to help as much as I can.;)
You didn't want those hooks to go anywhere did you! :D
/ Grind the bevel off weldable hooks? #32
Good idea...one can get poor penetration using stick as well as any other type of welding. Personally, I'm partial to TIG welding, but you'd need a big torch for enough heat to weld those hooks.
/ Grind the bevel off weldable hooks? #33
:laughing:
Oh Man!!! What a movie?:laughing:
/ Grind the bevel off weldable hooks? #34
:laughing:
Hate that when that happens!!!!:laughing:
/ Grind the bevel off weldable hooks? #35
Here is one of mine:
Miller 210, Lincoln L56 .035" wire, 75/25 gas.
Don't forget to tip the hook slightly away from the first side you tack-the heat will pull it straight, then weld the opposite side.
/ Grind the bevel off weldable hooks? #36
Here is one of mine.... Stick rules:cool2:
/ Grind the bevel off weldable hooks? #38
Good looking bead, Bro...
Thanks Roy, just my little chicom welder you see there at 125 amps some 1/8 inch US Forge 7018 .
This is on my Kioti, when I looked at the bead, the thought that went through my head was that my bead on the hook looked better than the MIG weld on the the little plate that the Korean guy did.
James K0UA
/ Grind the bevel off weldable hooks? #39
Good advice and a good lookin' bead, Kenny!!
I'll admit, I was a pretty decent TIG welder, but I couldn't do crap with MIG or stick!!
Best thing about being certified on TIG (while I was in the Navy) was it helped me identify good welds...and bad welds.
Now that I have a pacemaker, welding machines and I aren't a good mix...
2024 CATERPILLAR 279D3 SKID STEER (A65056)
2024 CATERPILLAR...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2018 HINO 268 4X2 S/A 26FT BOX TRUCK (A69167)
2018 HINO 268 4X2...
2025 JMR 38in Hydraulic Rock Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 JMR 38in...
2013 Ford F-150 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
