Getting new upper radiator hose on
/ Getting new upper radiator hose on #1
safe2assume
madison, nc
Kubota L2500DT
Hi all, I've searched the forum and cant find an answer. I have the new hose on the rad outlet but cannot get the other end to go on to the engine. Do I have to unbolt the rad and lift it up so the hose will just come down onto it? Should I heat it up first? Yes, I put lube on it lol.
/ Getting new upper radiator hose on #2
Assuming it's the correct hose, what I do is put the end of the hose in boiling water for a minute. It softens and expands it a wee bit.
Quick lube and slide it on. Use gloves as that hose end will be hot. Works for me.
/ Getting new upper radiator hose on #3
i second that idea,i use dawn liquid soap on the inside of hose so it slips on easily.
/ Getting new upper radiator hose on #4
I have never tried, heating the hose, What I would do first is try putting it on the rad first, I use soapy water as a lubricant, in a spray bottle.
I also use it on the hose when I put the clam on it alows the clamp to slide a bit and tighten evenly around the hose,
Just a thought!
I ended up boiling it for a few minutes and bending it in half, it was still an SOB to get on though.
It's the right one, very short and 90 degree bend, makes puttin on difficult!
/ Getting new upper radiator hose on #7
Like the others have said..."soap it up and/or warm it up". Since short hoses are usually very difficult to install, I always try to put the water pump (WP) side on first. Make sure the WP and radiator nipples are clean and free of any old hose residue and/or sealers and index it properly to the radiator/WP before you slide it onto the WP. Even so, it can still be a bear putting on.
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
White 6182 12R Planter (A66285)
White 6182 12R...
Yale 5K Forklift (A63689)
Yale 5K Forklift...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
