Getting new upper radiator hose on
   / Getting new upper radiator hose on #1
safe2assume
madison, nc
Kubota L2500DT
Hi all, I've searched the forum and cant find an answer. I have the new hose on the rad outlet but cannot get the other end to go on to the engine. Do I have to unbolt the rad and lift it up so the hose will just come down onto it? Should I heat it up first? Yes, I put lube on it lol.
   / Getting new upper radiator hose on #2
Assuming it's the correct hose, what I do is put the end of the hose in boiling water for a minute. It softens and expands it a wee bit.
Quick lube and slide it on. Use gloves as that hose end will be hot. Works for me.
   / Getting new upper radiator hose on #3
i second that idea,i use dawn liquid soap on the inside of hose so it slips on easily.
   / Getting new upper radiator hose on #4
I have never tried, heating the hose, What I would do first is try putting it on the rad first, I use soapy water as a lubricant, in a spray bottle.
I also use it on the hose when I put the clam on it alows the clamp to slide a bit and tighten evenly around the hose,
Just a thought!
I ended up boiling it for a few minutes and bending it in half, it was still an SOB to get on though.
It's the right one, very short and 90 degree bend, makes puttin on difficult!
   / Getting new upper radiator hose on #7
Like the others have said..."soap it up and/or warm it up". Since short hoses are usually very difficult to install, I always try to put the water pump (WP) side on first. Make sure the WP and radiator nipples are clean and free of any old hose residue and/or sealers and index it properly to the radiator/WP before you slide it onto the WP. Even so, it can still be a bear putting on.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
John Deere 7000 12R 30" Planter (A50515)
John Deere 7000...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
John Deere X740 Mower (A50514)
John Deere X740...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
