Frozen, Gelled fuel
/ Frozen, Gelled fuel #1
Firefighter Kubota
Seacoast NH
Kubota 7510
Well for the first time in 7 years of owning my tractor. My fuel gelled up on me...Mostly in the filter that I could see..
Its actually mid 20's right now but we've had a cold snap with single digits at night...
I know its been colder in the past... Maybe some crappy fuel... I have on occasion used an additive in the past, but it's been so mild I forgot this year...
Luckily I had a new still sealed de gel bottle from last year. Added it, topped the tank off, and after about 2 minutes of cranking running anfd dieing she cleared out...
Of course I had a bucket load of firewood and none in the basement, when she died...So getting her running was a priority..
Leason learned...
/ Frozen, Gelled fuel #2
What brand did you buy? I've been buying from Irving, I just figure they know how to refine winter diesel up in Canada.
It's random, but usually I end up at Irving or Hess...
Also, just cause its Irving doesn't mean its being trucked drown from Canada. I know they fill in Portsmouth and distribute from there
/ Frozen, Gelled fuel #4
I had the fuel gel up on my 5203 Deere two days ago, it was down in the single digits though. Started it and it ran for a couple minutes, sputtered and died. Tried adding some de-icer/anti-gel additive but it didn't do anything, I think it is plugged up in the petcock at the bottom of the tank as no fuel is reaching the filter. It's supposed to be warmer tomorrow so I'll see if it will start then.
After that incident I went and got some Power Service fuel additive which prevents gelling and added it to my B3200 along with a full tank of fresh fuel. Started yesterday in single digit temps and ran fine.
Honestly, in the very cold I mostly use my old Ford NAA. Starts right up regardless of the temp and warms up quickly, cold weather operation is one thing I still do like about a gas powered tractor.
Anyone else using Power Service diesel additive?
/ Frozen, Gelled fuel #5
I use Howse. Been recommended by a mechanic (does work on semis) and dealer
/ Frozen, Gelled fuel #6
It's shipped from Canada, offloaded at shore into terminal tanks, then trucked from terminals to stations. It's refined in Irving refinery, in Canada.
/ Frozen, Gelled fuel #7
I gelled up last winter,tractor and chipper. And that was with power service,trucks were ok but they have fuel heaters. I talked to the supplier and he said he spent the morning changing fuel filters on their trucks. I talked to a friend that works for another fuel supplier and they were not having any problems. Switched to them, switched to Howes and haven't had any more problems. Two years ago the tractor gelled up with power service, I added 911 red power service and was able to run that day but the filter never did unwax.
/ Frozen, Gelled fuel #8
Leason learned...
I learned that lesson in 2004 during my first full winter owning my previous BX2200. It hit -7 and it took me 3 days to get the tractor running. (Partly because I had no clue what I was doing and partly because of the untimely passing of my younger brother). I added a block heater shortly there after and I have never failed to use a fuel additive since that day. There are some that would say I am wasting my money on fuel additives but its a small price to pay for peace of mind in my opinion.
Sent from my iPad using TractorByNet
They must be using a 3rd party carrier...I also know other trucks are hauling " irving stuff" out of the terminal.. so I'm skeptical thats its all Irving...
I have a block heater too, but that wont help the filter.... point of most common gelling
/ Frozen, Gelled fuel #11
I think, if you continue looking into it, you'll find your skepticism unwarranted.
/ Frozen, Gelled fuel #12
The Irving refinery is right on the coast in St. John, New Brunswick, I imagine they just float the fuel down to Portsmouth by tanker. Citgo has recently expanded into my area, I was mostly wondering if it was their fuel.
I've been thinking about getting one of these to wrap around my truck's fuel filters: Kat's 24050 50 Watt 2"x 5" Universal Hot Pad Heater : Amazon.com : Automotive Could easily swap it over to a tractor filter in a pinch using a small bungee or elastic band.
Yup, not bad in a pinch... I think I can actually slide a large hot cup of water under my filter if needed
/ Frozen, Gelled fuel #15
First rule... Never trust Irving.. the cheap SOB's.
Secondly, treat all your fuel. Personally I use PSwhite, but once this bottle is done, Im going to another brand. I had a major gelling issue myself this year .
I ended up installing a better fuel filter (Racor) that handles water much better than the stock inline filter. I have not had a gelling or waxing issue since and the temperature has been way colder. http://www.tractorbynet.com/forums/kubota-owning-operating/268153-adding-spin-racor-filter-bx25.html
/ Frozen, Gelled fuel #16
I got my tractor back home by a " laying on of hands" one time. Wrapped my bare hands around the filter till the engine evened out and made a run for it!
Nice write up...I see a spring time project coming...
/ Frozen, Gelled fuel #20
This is my first experience with diesel, but from info I've gotten here on TBN I use PS. It's cheap from Wally and no probs. Though I'm sure the weather here is close to your's. Mine lives inside garage on a carpet even, but I don't want to take any chances especially when it's so easy to avoid.
2014 John Deere 1025R (A64126)
2014 John Deere...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
